Timing Belt Wobble. Need Help!
Old 15 Jan 2015, 05:16 pm
Default Timing Belt Wobble. Need Help!
Hey guys I've got a problem with a recently replaced timing belt. For some reason it wants to track in and out when running. I have repositioned the belt numerous times but it keeps going back to the same spot moving in and out almost immediately when started. 2007 non turbo pt cruiser.
Old 15 Jan 2015, 05:31 pm
cruserdad1976's Avatar
Default Re: Timing Belt Wobble. Need Help!
pulleys are out of align somehow
Old 15 Jan 2015, 05:33 pm
Is the center bolt tight on the adjuster?
Old 15 Jan 2015, 05:48 pm
The bolt is tight and I didn't take the cam pulleys off. I did the feeler gauge thing behind the crank pulley to ensure it was going back the same. Is it possible that the belt is warped from the manufacturer?
Old 15 Jan 2015, 06:53 pm
Going back and forth is a bit strange. Does any of the idlers or other pulleys seem to wobble? What brand?
Timing belt Deepstar Tech & Performance Forum 7 13 Jan 2013 05:19 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
