Cam shaft sensor
  • 1 Post By quicksilverdon
Old 16 Jan 2015, 06:21 pm
Angry Cam shaft sensor
I have a 2006 PT crusier and I have had a problem with my camshaft sensor 4 times I have replaced it 1st time @ 10000 miles 2nd time At 20,000 miles 3rd time at 34,000 miles and now again last week at 45,000 miles. I have tried to see if there has been a recall but nothing shows up does anybody else have this problem. I brought this brand new in 2006 and have been the only owner.
Old 16 Jan 2015, 06:31 pm
LionPT's Avatar
Default Re: Cam shaft sensor
It might seem frustrating to have to replace it every few years while others don't...but at about $35 it could be something worse...JMO
Old 16 Jan 2015, 06:42 pm
Are you using Mopar sensors?
Next time, unplug and replug connector - many times it's wiring/connector, not sensor.
NitroPT likes this.
Old 16 Jan 2015, 06:46 pm
IMHO your problem is not and most likely was not the senors!
In this case because you are only replacing a suspected part and not doing better diagnostic search for the real issue you may consider taking your PT to a shop that you first qualify has a ASE Diagnostic Technician specifically experienced with CAN-bus diagnostic repair that can assess the problem.
Cam Shaft sensor problem lokiloki Tech & Performance Forum 10 28 Aug 2013 10:27 pm
What's the rubber line called near the cam shaft sensor? Mr_Clay General Turbo Discussions 0 07 Aug 2011 08:32 am
crank shaft positioning sensor?? help! xodeflepgirlox Tech & Performance Forum 3 08 Oct 2010 07:41 pm
Code P0340 Cam Shaft Position Sensor A Leroy Western PT Forum 4 02 Apr 2010 04:01 pm
Cam Shaft Position Sensor Johns Steel Blue Tech & Performance Forum 9 15 Apr 2008 07:38 pm
