Foamy power steering fluid
  • 1 Post By LionPT
Old 18 Jan 2015, 10:38 am
Wink Foamy power steering fluid
What does it mean when I hear a squealing in the power steering, I shut the engine off, look at the fluid level and see.............all foam stuff?
I try and take some of the foam out, add fluid and after about 5 min, everything is good again.
This only happens every so often. It is not a daily thing.
Should I get some Lucas Oil power steering sealer? I am on retirement and do not have alot of money to replace pump or anything like that.......
Thanks for all your advice...
Old 18 Jan 2015, 10:49 am
LionPT's Avatar
Default Re: Foamy power steering fluid
It sounds like you have air in the lines...
Take the power steering cap off...check fluid level, start car & turn the wheel all the way to the right then left about 6 times...check fluid level & replace cap.
This should get all the air removed unless you have a leak somewhere.
Old 18 Jan 2015, 11:38 am
Here's a few good answers on this "Car Talk" site of why it might be foaming...
Steering fluid foaming - Car Talk
...and PLEASE Don't ask the same question in more than one place on the forum.
Power Steering Fluid Aquamarine General PT Cruiser Discussions 1 01 May 2013 04:21 pm
Power Steering Fluid ptal Tech & Performance Forum 4 05 Mar 2010 09:40 pm
Power Steering Fluid jmack General PT Cruiser Discussions 12 25 Dec 2008 11:55 am
Gasoline and Power Steering Fluid DIYPTGUY General PT Cruiser Discussions 11 29 Nov 2008 01:47 am
TSB on Power Steering fluid? PTGT Redman Tech & Performance Forum 10 31 Mar 2004 06:42 pm
