TIPM Differences
Old 20 Jan 2015, 01:15 pm
Default TIPM Differences
Hello, Im from Argentina (south far away) and i have a 2006 PT Cruiser CRD 2.2 Classic. Iam very pleased with this car but suddenly it started with problems with A/C. I found a leakage so i had tu change my Condensser, and afeter a time it stopped sending Cold Air. I found compressor was not Starting. The problem was a melted wire that was solved. But my mechanic said that perhaps my TIPM could be broken. I took the part number of the TIPM (56049719AN) and found that teh number of the replacement is the same but have different letters (AK). Does anyone knows what teh letters stand for? or, is there any difference with that?
Thanks a lot!!!
Old 28 Jan 2015, 01:49 am
dalandon's Avatar
Default Re: TIPM Differences
The "AK" part of the number is the revision generally AA would be the original and going up to AK, be sure its for a 2006 second generation which uses canbus
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 28 Jan 2015, 10:03 am
Since you have a diesel, you'llfind this helpful:
Useful online CRD service guides
Old 28 Jan 2015, 10:07 am
Originally Posted by deadmeat View Post
Hello, Im from Argentina (south far away) and i have a 2006 PT Cruiser CRD 2.2 Classic. Iam very pleased with this car but suddenly it started with problems with A/C. I found a leakage so i had tu change my Condensser, and afeter a time it stopped sending Cold Air. I found compressor was not Starting. The problem was a melted wire that was solved. But my mechanic said that perhaps my TIPM could be broken. I took the part number of the TIPM (56049719AN) and found that the number of the replacement is the same but have different letters (AK). Does anyone knows what teh letters stand for? or, is there any difference with that?
Thanks a lot!!!
Are you still having problems with the AC or something else?
I think you may be referring to the PCM with those numbers
PCM has VIN programmed and if you have the security key with the chip ( large grey thumb end)and SKIM module
it may start a few times for a second or two then set the theft deterrent red light on the instrument panel and will not work.
the TIPM has the fuses and relays under the cover
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
TIPM Replacement ptjumpstartpro Tech & Performance Forum 1 10 Oct 2014 03:37 pm
TIPM help klarsen01 Tech & Performance Forum 13 03 Mar 2014 03:29 am
TIPM veracruise Tech & Performance Forum 3 17 Jan 2014 03:50 pm
The TIPM and my experience 06SesiBlu Tech & Performance Forum 2 11 Jun 2013 02:44 pm
faulty TIPM nhpt Tech & Performance Forum 2 12 Sep 2010 04:33 pm
