in need of help. asap
Like Tree2Likes
Old 21 Jan 2015, 12:17 pm
Exclamation in need of help. asap
I have a 2.4 pt all stock. 190k
I had a misfire. even the codes were showing a misfire. so I replaced everything I could. the spark plugs.the wires, the coil pack. even the valve cover gaskets because there was oil where the plugs were. I had to replace two hoses one coming from the intake to the valves kind of thin. and a thick one which I believe is the vacuum valve. I thought there may have been a kink but they are as open as can be.
But, after replacing all of that. I though all was good until I came to a stop and my car is just running. It begins to idle really low, it has a shake to it and acts like it wants to turn off. on some occasions the engine has completely stopped running. and on other occasions it has the shake and the put as if it is misfiring again.
as you may can tell I am not very knowledgeable about cars so I need as much help as I can get. It is the only car we have at home and it's very important to get the solution. so thank you in advance for the help.
Old 21 Jan 2015, 12:32 pm
LionPT's Avatar
Default Re: in need of help. asap
Are you still seeing any codes..??
Old 21 Jan 2015, 12:34 pm
the engine light is on but I haven't been able to check them. I can check as soon as I get off of work
sounds like a vacuum leak. check the hose by the brake booster on the firewall, driver's side. I remember a few peeps having a problem with the hose coming off.
2016 Kia Soul Plus Black
Old 21 Jan 2015, 12:44 pm
You posted the same on this thread:
Coil? or Converter? Or?
Since you replaced plugs and wires, next most common cause is intake gasket leak.
Runs okay except for rough idle?
Also could not hurt to add injector cleaner to gas.
Old 21 Jan 2015, 01:21 pm
I'll give it a look. thank you.
Old 21 Jan 2015, 01:22 pm
I did post on that thread as well, because I felt it was very similar
And I did replace the valve gaskets as well. and correct it runs fine unless it is stopped/idling
Old 21 Jan 2015, 02:00 pm
Well, after gaskets, next most common is a stuck/clogged injector, and then poor compression - usually a valve issue.
Definitely try injector cleaner, and a compression test would be a good idea.
Old 21 Jan 2015, 02:02 pm
I will pick some injector cleaner up immediately. so do I take it to a shop to get the compression test or how would I do so?
Old 21 Jan 2015, 10:23 pm
I would suggest before we start guessing and spending hundreds of dollars and many hours of labor to find out what are the engine trouble codes and go from that point.
Tags
help please, help quick
Help Asap sconnors11 General PT Cruiser Discussions 21 09 May 2012 08:42 am
Need Help Asap! Busa_Powered General PT Cruiser Discussions 4 02 Jan 2012 01:04 am
NEED HELP ASAP!!!! myyellowty General PT Cruiser Discussions 5 21 Dec 2008 08:21 am
NEED HELP ASAP gopackers General Turbo Discussions 5 20 May 2008 12:04 pm
PLease help asap turbomangt General PT Cruiser Discussions 5 12 Oct 2003 12:00 am
