Noise from front wheel. CV joint or bearing??
  • 1 Post By Busted_PT
Old 25 Jan 2015, 03:49 pm
Default Noise from front wheel. CV joint or bearing??
Thought it was brakes at first but new pads and discs on it when I checked.
Put hands at 12 and 6, shook wheel, no movement.
Put hands at 3 and 9, shook wheel and there was movement, changed faulty tie rod end. No movement now.
Whilst jacked up and turning wheel it makes no noise. Rubber boots on CV joints all intact.
It makes this noise every right turn and occasionally going straight. As parts ain't cheap I'm asking for advice on what this could be or if any of you have experienced the same.
Put video on you tube there now 2002 PT Cruiser noisy front wheel problem - YouTube
Thanks guys.
Old 25 Jan 2015, 04:33 pm
LionPT's Avatar
Default Re: Noise from front wheel. CV joint or bearing??
From my experience, it's usually the opposite wheel that is bad...your hearing noise making right turns, check the left bearing.
But, from that video...it sounds like something is rubbing...check the plastic wheel well covers on both front tires.
Old 25 Jan 2015, 05:04 pm
I've checked for anything that could be rubbing both jacked up and on the ground. Nothing found. As I come to a stop and the noise gets slower it really sounds like a rubbery squelchy noise.
I have a facebook group for buying and selling cars and someone on it who had a PT previously mentioned shaft bearings???? I asked him did he mean the gearbox output bearings but no response as yet.... Its a strange one....
Old 26 Jan 2015, 01:20 pm
Update: started making noise on left turns now too, also feeling the slightest wobble in steering wheel.
Old 28 Jan 2015, 01:42 am
dalandon's Avatar
Wow that's loud
Its a thump thump sound?
when was the last time you checked the rear hubs?
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 28 Jan 2015, 04:21 am
Are the brakes pulsing coming to a stop? You could have warped rotors and bad lower Control Arm Bushings
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 28 Jan 2015, 04:50 am
Only bought it last week. Rotors are pretty much brand new, have checked for warping and they're fine. Its turned into more of a creaking/grinding noise now. When I apply brakes there's a pulsing in brake pedal but only for 1 second then it goes away and it's normal feel.
Noise is definitely coming from front and most noticeable at low speeds. Very slight wobble in steering wheel, hardly noticeable.
If wheel bearing was shot, is it possible there could be no movement in wheel when jacked up? When I jack it up there's no movement in wheel at all, hopefully I can rule that out if so.
Old 28 Jan 2015, 12:01 pm
bubba_1952's Avatar
It may be the CV shaft going bad as when mine went it first sounded like a flat tire then a grinding noise.
Bubba
Old 28 Jan 2015, 12:58 pm
But you have movement that you're feeling. So as for the wobble and pulsing that shouldn't be the problem. Doesn't mean they aren't the sound. If you have to pull the axle. You can turn the bearing by hand to see if they feel rough.
Slowrider likes this.
Front end noise, but not the hub bearing??? ptnoob1973 Wheels, Tires, Suspension 22 29 Nov 2014 08:27 am
noise from engine after 30km/hr not wheel bearing ddash General PT Cruiser Discussions 9 17 Dec 2010 11:54 am
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
