Check Engine Light
Old 27 Jan 2015, 07:41 pm
Default Check Engine Light
The Check Engine light is on in my 2001 PT Cruiser. When this has happened in the past a new gas cap solved the problem. Not so this time. The codes P0442 and P0455. I recently had to remove the battery to access transmission pump hoses (used for towing the PT behind an RV). Is it possible I knocked a vacuum hose loose? Or? Thanks for all the help.
Old 27 Jan 2015, 09:03 pm
Default Re: Check Engine Light
You would have notice the condition very quickly if it happened then. I would follow all the the big vac lines to see which ones are bad. Start at the brake booster and go from there.
Old 27 Jan 2015, 11:23 pm
I would suggest if you have checked all the hoses to do a smoke machine test and see where the smoke starts to leak from in the evap system.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Check Engine Light on bucksfan1976 General PT Cruiser Discussions 9 04 Aug 2010 09:47 pm
