Mysterious overheating.
Old 31 Jan 2015, 12:35 pm
Question Mysterious overheating.
2001 PT Cruiser 2.4L has been starting to overheat. When I have idling the temperature gauge starts to rise. This is where it gets odd. If I have the fan set to anything on the heat side the temperature gauge keeps rising. But if I switch it over to the air conditioning side the temperature gauge will show that the engine is now cooling off and running at a normal temp but sometimes even then my temp gauge will go about 3/4 before it starts to cool down. Also sometimes (it's been pretty sporadic) my blower will seem like it's not pushing out the normal amount of air but when I shut the car off and wait an hour or so it's fine again. The thermostat has been replaced and I hit a raccoon last year and had to replace my radiator. I have no clue what could cause it to be doing the rest of this.
Old 31 Jan 2015, 03:43 pm
Default Re: Mysterious overheating.
Sounds like you may have two problems. One of the fan speeds may be burnt out (common problem) and the Low Pressure Switch, also known as the Recycling Switch (located on top of the accumulator) may be bad (not so common problem).
Old 31 Jan 2015, 03:46 pm
When the engine is COLD, take the radiator cap off the thermostat housing and make sure it's filled to the top. It may be a good idea to pressure test the cooling system to check for leaks. Also, check to make sure the radiator cooling fans are operating at both speeds.
2008 PT Cruiser Touring 135,000 miles
Old 31 Jan 2015, 06:41 pm
I've been trying to search for a low pressure switch with no luck. Any clues? Or will I have to go to a dealer :/
Old 31 Jan 2015, 06:48 pm
Shouldn't be hard to find. Chrysler part No.#5016-417AA Switch Kit. A/C Cycling.
Old 31 Jan 2015, 07:08 pm
Your overheating problem is because your low speed on engine fan doesn't work - turning on A/C causes the high speed on fan to come on, which cools off engine.
Don't know about your airflow issue.
Old 31 Jan 2015, 07:38 pm
That air flow problem is something I had and it was traced down to the Recycling switch so that's way I mentioned it as a probably cause.
2001 PT mysterious cruise control JDeProniio General PT Cruiser Discussions 2 28 Jul 2014 10:36 pm
A foul & mysterious odor.. PawsToDream Tech & Performance Forum 11 07 Jun 2014 01:26 pm
Mysterious Rattling Noise Gone Hoosier Tech & Performance Forum 16 25 Aug 2013 08:09 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
update on that mysterious rear knocking noise Ctown General PT Cruiser Discussions 6 25 Apr 2006 09:55 am
