Transmission filter Installation Question
Old 09 Feb 2015, 09:54 am
Default Transmission filter Installation Question
Changed my transmission fluid and filter this weekend, but really struggled with getting the filter to stay in place while re-installing the pan. In videos I've seen it looks like the filter is supposed to "lock" into the base of the transmission with the two plastic pins and O-Ring friction. Mine never, or barely held on, and would fall at the slightest touch. Even purchased a second filter thinking the pins on the first must be faulty, but it didn't make a difference. Is there a trick to mounting the filter without having to double-up on the blood pressure meds?
Think it finally all lined up and I'm hoping the pan itself will now keep filter from moving. Am I making a rookie mistake?
Old 15 Feb 2015, 02:55 pm
Default Re: Transmission filter Installation Question
I like to put new transmission fluid on the O-ring that goes on the filter to help it slide in easier. I can't remember exactly how many nipples were on the filter but once you line them up with the holes, they'll snap in. Double check to make sure you have the right filter if it's not going in.
2008 PT Cruiser Touring 135,000 miles
Old 15 Feb 2015, 03:45 pm
When I changed mine the filter sort of snapped up and stayed there... Remember how much it took to pull it off?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Tags
transmission fluid change
transmission filter has metal in it? 03ptatx Tech & Performance Forum 23 29 Jan 2015 09:53 pm
Transmission Filter replacement shortattentionspan General PT Cruiser Discussions 1 28 Jul 2013 07:01 pm
Transmission fluid filter/pan clearance question? ingram87 General PT Cruiser Discussions 7 16 Apr 2012 09:22 am
transmission filter 2007 bompa45 Tech & Performance Forum 5 26 Apr 2009 10:46 am
general cabin filter question and installation tip pppt03turbo Interior Accessories Forum 25 22 Aug 2008 08:26 am
