Help! Possible electrical problems?
Old 09 Feb 2015, 10:10 am
Default Help! Possible electrical problems?
Hey everyone, I'm hoping I'm posting in the right forum.
On Friday evening, I drove my 2004 PT Cruiser home. Not even 15 minutes later, I get back in the car ready to go, put the ignition key in and turn it over, and bam - nothing. I was in reverse and the car slowly backed up a few inches but the engine was not even on, just the electric system.
I had my friend come over yesterday, at first we thought there was a problem with the solenoid. My starter ended up being perfectly fine. Fuses are fine as well. The battery still has life in it and works. I just can't get the engine cranking with my key anymore.
So my question is, do I just need to get a new programmed key? I'm assuming it is an electrical system problem. Do keys just randomly stop working? I've had this one for around a year. The lights and radio still work when I put my key in.
Thanks guys
Old 09 Feb 2015, 11:37 am
Default Re: Help! Possible electrical problems?
Thanks guys
I'm assuming you have a manual - since if I read correctly, you moved the car with transmission in reverse with the starter???
I thought there was a safety switch where clutch had to be in for stater to turn - so I don't get how you could move car by starter.
Also, starter doesn't go directly to gearbox, it turns engine, which then turns the gearbox, so I think it did turn your engine over, just not quickly.
Have your battery checked - start there...
Old 09 Feb 2015, 01:04 pm
My battery has been checked and it's fine.
I actually have automatic, - it's weird, the car was slowly backing up when I put it in reverse but the engine was not on.
Tags
ignition, key
Electrical problems jedidiah55 General PT Cruiser Discussions 0 11 Nov 2014 09:09 pm
electrical problems KJT Tech & Performance Forum 6 27 May 2013 01:23 pm
PT Electrical Problems DDPTman Tech & Performance Forum 1 17 Feb 2009 03:34 pm
Electrical problems? Help please. cupcake Tech & Performance Forum 6 24 Jan 2009 04:49 pm
Electrical Problems sdalley Tech & Performance Forum 3 08 Nov 2008 06:20 pm
