Need Help with Codes
Old 09 Feb 2015, 10:49 am
Default Need Help with Codes
So I was driving my car 4 days ago and when I got home I went to turn my car off, I took the key out of the ignition, the car stayed running for about 45 seconds before it finally turned off. The next time I turned my car on the check engine light was on. I should let you know that in the past 4 days, the car has shut off correctly about 3 times and has not shut off correctly approximately 8 times. Today it actually stayed on a little bit longer that usual and worried me. I went and had it tested at O'Reileys yesterday and 3 codes came up. The problem is, the guy told me he couldn't tell me what the codes were for my car because the codes start with a "U" instead of a "P".
The codes I got are:
U110C: Lost fuel level message
U0141: Lost communication with body control module
U1411: Implausible fuel volume signal received
I can't find any information on how to fix this/these problems. I need this cleared ASAP because I need to go get my car emission so I can reregister it. any help is greatly appreciated.
I have a 2006 2.4L touring edition manual tranny with approx. 95,000 miles. I just changed spark plugs and wires 5 months ago.
Old 09 Feb 2015, 11:07 am
LionPT's Avatar
Default Re: Need Help with Codes
I can't tell you how to fix...but it does seem like a fuel to computer/communication issue.
Old 09 Feb 2015, 11:15 am
The year your PT Cruiser is?
I am guessing CANbus system 2006 or newer PT?
You are going to need a readily available use of a scanning tool if you are going to be attempting to solve your issues.
Old 09 Feb 2015, 11:59 am
Sorry, it's a 2006
Old 09 Feb 2015, 12:00 pm
What good is the scanning tool going to do me if the codes can't be found for my car that are coming up?
Old 09 Feb 2015, 12:41 pm
What are you talking about ? You even posted the definitions of the codes in your first post...
U110C - a communication failure between the BCM and the PCM on the fuel level bus line
use a search engine.
Old 09 Feb 2015, 01:47 pm
OK... If you read my post then you seen I said I wasn't able to find any information on how these codes relate directly to my car. That is the generic code info that comes from the code reader. It doesn't tell me what could be causing the problem. I am asking if someone could know what problem(s) those codes could be causing. I did a google search and nothing was found.
Old 11 Feb 2015, 12:18 pm
Exclamation Re: Need Help with Codes
I'm still in need of help if anyone can please help me out with the codes for my car. I need to get my car emission immediately
Old 11 Feb 2015, 03:08 pm
I would suggest checking your ground wires. Check and make sure the ground wires going to the drivers side fender are making good contact.
Also check the battery. Make sure battery fluid levels are okay. Some of the PT Cruisers are known to give the battery a hard time on the 2 generation. The PT Cruisers are sensitive to voltage drops so when you have a weak ground it will lower the voltage and sometimes triggers no communication trouble codes on some of the modules.
Old 12 Feb 2015, 11:25 pm
Would that also cause the car to stay running for a short period after I remove the key from the ignition?
codes genet General PT Cruiser Discussions 7 08 May 2013 04:12 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
Codes? BladeRunner Tech & Performance Forum 4 12 Apr 2011 10:07 pm
