engine bucking bronco
  • 1 Post By ptcruisersteve
Old 14 Mar 2015, 11:12 pm
Default engine bucking bronco
While driving highhway speed, engine started to buck and as i eassed off the gass, engine light came on. I was able to keep it going around 40 or 50 mph.. If I applied gas to fast the engine would buck and not respond. Then I noticed that cruise control stopped working..I made it home....50 miles later..any thoughts, have to take it to shop on Monday!
2004 limited. 145,000 miles.timing belt, plugs and wires changed at 100000.
Old 14 Mar 2015, 11:17 pm
Default Re: engine bucking bronco
Check your engine codes. Mine did this and it was the cam position sensor. Easy fix, if that's it.
Old 15 Mar 2015, 01:47 am
If it is the camshaft sensor engine trouble code P0344 try checking the wiring and the connector. If both is okay then check the camshaft sensor. it is recommended to buy only Mopar sensors.
Its pretty easy to replace.
Attached is a link to a video that shows how to replace the camshaft sensor.
Old 15 Mar 2015, 03:28 am
rockandroller's Avatar
And if you are in limp mode due to that code - disconnecting the battery for a few minutes will clear it, and it will run normal again. Mine did that for a week, before it threw another code. Then I cleared it again, and got another week.
Then it threw one again, and I went and bought a genuine Mopar sensor ( $100 at the local Stealership, but its been fine ever since...)
2004 'Turbo Lite'
Old 15 Mar 2015, 02:09 pm
soonercruiser's Avatar
Cool Re: engine bucking bronco
Gonna bet it's the Cam sensor!
Doing mine right now on a 2005 at 45K.
Code 0339!
I had some appointments for her, like custom pin striping job.
So, I've been driving around under 2,500 rpm and all is well for now.
Frank, aka SOONERCRUISER,
Old 15 Mar 2015, 02:20 pm
Code 0339!
Soonercruiser
Isn't the code P0339 for the crankshaft sensor?
soonercruiser likes this.
Old 17 Mar 2015, 07:43 pm
Smile Re: engine bucking bronco
Thank you everyone. this is the best forum! I replaced cam sensor and so far car is running great and Cruise control is back. Did not have access to computer codes, so I took a chance and replaced anyway, since 4 out of 4 of you said the same thing. BTY, dealer had same price as Internet and I installed same day! $70 bucks and I'm back on the road!
Thank you, thank you,
John
Old 17 Mar 2015, 09:45 pm
Unhappy Re: engine bucking bronco
Originally Posted by ptcruisersteve View Post
Soonercruiser
Damn!
You're right!
I didn't look close enough.
Bucking PT dvddmc Tech & Performance Forum 6 10 Jun 2013 10:48 pm
2006 PT Cruiser bucking when accelerating + no check engine codes mattamusprime General PT Cruiser Discussions 4 26 Mar 2012 08:59 pm
03 Stage 1 2.4 Engine miss/bucking getuoutthere Stage Turbo Kits 7 15 May 2011 04:29 pm
Bucking bquik Tech & Performance Forum 5 06 May 2010 08:26 pm
Engine Light + Bucking When Accelerating kalyhan Tech & Performance Forum 9 06 May 2010 10:06 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
