PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Procedure for changing wires and plugs?
Old 05 May 2004, 03:43 pm
snakepitt1 snakepitt1 is offline
Default Procedure for changing wires and plugs?
I have looked for this thread, but, can't find it.
Is there a procedure for doing the plug / wire / coil change? Specifically, the removal of the intake runners, any seals that need to be replaced, special things to watch out for, or tips to make the job easier on a non-turbo.
Thanks,
Scott Harris
[8)]
Old 05 May 2004, 04:10 pm
KingKole02 KingKole02 is offline
here is some
http://www.imagestation.com/member/j...d%3D4291473219
http://ptcruiserlinks.com/forum/topic.asp?TOPIC_ID=5912
KingKole02
SW Florida PT Cruisers
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
For cruiser pics go to:
http://ptcw.truckmoxie.com/mygallery.ten?id=3464
http://smg.photobucket.com/albums/v8...0in%20my%20PT/
For my personal page, visit
http://www.kingkole02.com
http://random-input.blogspot.com
http://www.ptcruiserweekly.com
www.jumpsometravel.com Travel Everywhere! - Owner
Old 05 May 2004, 04:35 pm
CREWZIN CREWZIN is online now
Snakepitt1,
The 2 links that KingKole gave you should cover what you need "if" you can log into Imagestation for the first link. If not, the second link should do the trick. Two hints that I have to share are: (1)after you take out/loosen the 5 small upper manifold bolts, my cruiser (2001) had a wire "U" clip that attached to the 2nd or 3rd bolt that went 3/4 way round the upper radiator hose to keep it straight. Don't just pull all the way up on the upper manifold without reaching around and getting that "U" clip from the radiator hose. (2) after the new plugs and wires are in, the first thing you want to do is try and get the EGR bolts (2 of them) back into the holes before you actually put anything else back together. These two bolts are the most annoying things on the whole job to get back in. If you can just start the bolts in the threads that will be enough to continue putting the rest back together.
Old 05 May 2004, 05:04 pm
I will use this advice as well when I need to chance my plugs. Thanks
KingKole02
Old 06 May 2004, 10:22 am
Thanks,
Scott Harris
[8)]
I didn't disconnect any throttle linkages - just pivot the intake up & prop it with a stick - less to re-assemble. [?]
Old 06 May 2004, 05:03 pm
quote:Originally posted by quicksilverdon
You mean you don't have to disconnect all the stuff in the guide above??
KingKole02
Old 06 May 2004, 07:02 pm
Colby,
There is a shorter cut as QSD stated. The only things to take off are the five small upper manifold bolts, the 2 EGR bolts on the back of the engine, and one bolt that attaches the upper manifld to the throttle body. Also the intake tube that comes from the air filter needs to come off of the throttle body. There's a black rubber tube on the right side and depending on the air filter you have, sometimes that has to be taken off where it attaches to the manifold. No electrical connections need to come off, just lift up the front of the manifold and use some sort of tie to keep it away as you change the ignition parts.
Old 06 May 2004, 07:49 pm
Hooligan Hooligan is offline
I went to PTDoityourself.com and used the info in the Quick Tips section AFTER I read thru all of the service manual stuff.
One thing CREWZIN didn't mention, is be careful as there is a brass bushing in the part that the throttle body is bolted to. Don't drop it!!! Just be aware of it.
Old 07 May 2004, 09:18 am
This sounds like the same set of info that is mentioned in the guide I provide through imagestation.
Thanks for anymore info you could provide.
KingKole02
vB code is On
Rough Idle on 2003 Pt- Not plugs and wires Jungle Jim Tech & Performance Forum 6 27 Mar 2007 09:22 am
New Plugs & Wires ? BB General Turbo Discussions 5 09 Jan 2007 12:37 am
Just changed plugs & wires gonzomania Tech & Performance Forum 2 04 Aug 2005 05:13 pm
3/25/05 UPDATE - DONE! - New Plugs and Wires NGK BumperBob Tech & Performance Forum 14 31 Mar 2005 01:06 am
Plugs & Wires BACKinMOTION Tech & Performance Forum 4 11 Jan 2004 01:36 am
  Adsense Paying Keywords | Secured Loans | Cheap Flights | Car Finance | Mouth Cancer
