Cooling fan not running??
Like Tree4Likes
  • 1 Post By JoeX
  • 3 Post By drumrooster
Old 21 Mar 2015, 04:18 pm
Default Cooling fan not running??
01 PT 5 SPEED..Radaitor fan not coming on? I know its supposed to go into high speeed when the AC is on,,but it dont even come on..on low whne it gets to temp or AC...question is weres the relay? or fuse? thought id check that first..
then get a few fan assembly..thanks...
Old 21 Mar 2015, 04:41 pm
Default Re: Cooling fan not running??
The relays are in the PDC (Power Distribution Center) which is the black box in the engine compartment behind the battery. The relays are the square boxes.
The radiator fan has one fuse No# 5 in the same PDC.
Old 21 Mar 2015, 05:35 pm
Remember 1 ground two speeds.
There are three wires in the harness going to the fan, the center one is ground.
If that wiring harness connector ground is bad you loose both hi and low speed.
(mine did the same thing) I ran a ground wire to the fan side of the connector harness.
FIXED it. I had already replaced the fan assembly because it had over 100,000 miles.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 22 Mar 2015, 05:18 am
Are you getting any engine trouble codes?
I just received my new radiator fan from Rock Auto for my 2008 PT Cruiser with only 80,000 miles on it. My radiator fan has not failed yet but I am not taking a chance and for $82.00 its well worth it considering the possibility of my PT Cruiser overheating.
I did get the engine trouble code for the high speed on my 2007 Pt Cruiser about six months ago and replaced that radiator fan on that one. Its a peace of mind knowing that my wife's PT Cruiser has a new radiator fan and has a good chance of not overheating.
Do you know when was the last time the radiator fan was replaced on your PT Cruiser?
Old 22 Mar 2015, 12:15 pm
Ray_Dockrey's Avatar
The fan on my 09 failed at 79,000 miles. No trouble codes It would idle rough with the AC on and start to overheat but would cool back down with the AC off.
Old 23 Mar 2015, 09:13 am
Checked relays
.jumped the fan..no work in slow or high mode..replaced fan workin great now..thanks guys
2006 PT cooling fan keeps running/dead battery pmexaminer Tech & Performance Forum 13 18 Oct 2014 09:07 pm
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
Cooling Fan Always On When A/C Running? TedEbear General Turbo Discussions 5 10 Jul 2012 06:19 pm
Car Not Running - Help plang1975 Tech & Performance Forum 8 28 Oct 2008 12:15 pm
XM up and running CHROMEDCRUISER Sound and Security Forum 4 07 Jan 2005 07:22 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
