New Toy
Like Tree2Likes
  • 1 Post By ptcruisersteve
  • 1 Post By NitroPT
Old 22 Mar 2015, 09:45 pm
Default New Toy
Got some OBD sortware and I am just learning. Know the basics but her is what I have..........................
Diagnostic Report
Created by OBDwiz - OCTech, LLC www.obdsoftware.net
Date: 3/22/2015 10:19:12 PM
VIN: Not Available
Monitor Status Report
Name Continuous Available Complete
Misfire Yes Yes Yes
Fuel System Yes Yes Yes
Components Yes Yes Yes
Catalyst No Yes No
Heated Catalyst No No No
Evap System No Yes No
Secondary Air System No No No
AC Refrigerant No No No
Oxygen Sensor No Yes No
Oxygen Sensor Heater No Yes No
EGR System No Yes No
MIL On
Number of Stored Codes: 0
This vehicle is not ready for emissions testing.
Trouble Code Report
There are no pending, stored, or permanent diagnostic trouble codes (DTCs).
Service $01 - Powertrain Diagnostic Data
PID Description Value Units
SAE 0x03 Fuel system status Open-loop due to insufficient engine temperature
SAE 0x04 Calculated load value 0 %
SAE 0x05 Engine coolant temperature 63 F
SAE 0x06 Short term fuel % trim - Bank 1 0 %
SAE 0x07 Long term fuel % trim - Bank 1 0 %
SAE 0x0B Intake manifold absolute pressure 100 PSI
SAE 0x0C Engine RPM 0 RPM
SAE 0x0D Vehicle speed 0 MPH
SAE 0x0E Ignition timing advance for #1 cylinder 0
SAE 0x11 Absolute throttle position 15.29 %
SAE 0x13 Oxygen sensors present Bank 1: Sensor 1, Sensor 2, Bank 2: None
SAE 0x14 O2 voltage (Bank 1, Sensor 1) 0.3 V
SAE 0x14 Short term fuel trim (Bank 1, Sensor 1) 0 %
SAE 0x15 O2 voltage (Bank 1, Sensor 2) 0.28 V
SAE 0x15 Short term fuel trim (Bank 1, Sensor 2) 99.22 %
SAE 0x1C OBD requirements to which vehicle or engine is certified OBD II (California ARB)
SAE 0x21 Distance traveled while MIL is activated 0 km
Custom 0x00 Input voltage read by the scan tool 13 V
Service $02 - Freeze Frame Report
A freeze frame was found but the vehicle has no stored trouble codes. This indicates that the freeze frame could contain out-of-date and inaccurate information.
0x03 Fuel system status Unknown
0x05 Engine coolant temperature -40 F
0x06 Short term fuel % trim - Bank 1 -100 %
0x07 Long term fuel % trim - Bank 1 -100 %
0x0B Intake manifold absolute pressure 0 PSI
Service $05 - Oxygen Sensors
Sensor Available
Bank 1 - Sensor 1 Yes
Bank 1 - Sensor 2 Yes
Bank 1 - Sensor 3 No
Bank 1 - Sensor 4 No
Bank 2 - Sensor 1 No
Bank 2 - Sensor 2 No
Bank 2 - Sensor 3 No
Bank 2 - Sensor 4 No
Service $06 - On-Board Monitoring
Component Description Value Minimum Maximum Units Result
Component Id $00 TID $16 - Manufacturer Defined 4 17 N/A Fail
Component Id $00 TID $17 - Manufacturer Defined 31 N/A 31 Pass
Component Id $00 TID $63 - Manufacturer Defined 6 N/A 39 Pass
Service $09 - Vehicle Information
General Information
Description Value
Vehicle Identification Number Not Available
Calibration ID - $18 05034014AA
Calibration ID - $10 05033664AC
Calibration Verification Number - $18 72FE4F5B
Calibration Verification Number - $10 1C3C5601
Wondering about this one....Component Id $00 TID $16 - Manufacturer Defined 4 17 N/A Fail . Anyone have a clue as to what failed?
Thanks
2002 2.4 auto 130k and still going.
Old 22 Mar 2015, 10:34 pm
Default Re: New Toy
There is not much information on these mode 6 hex codes.
Chrysler does not provide information on Mode $06 codes.
Good luck.
TID 16 O2
TID 17 O2
TID 26 O2
TID 27 O2
TID 28 O2 Heater
TID 29 O2 Heater
TID 2A O2 Heater
TID 2B O2 Heater
TID 2C O2 Heater
TID 2D O2 Heater
TID 2E O2 Heater
TID 2F O2 Heater
TID 36 O2
TID 37 O2
TID 3D Catalyst
TID 3E Catalyst
TID 55 EGR
TID 56 EGR
TID 57 EGR
TID 58 EGR
TID 59 EGR
TID 5A EGR
TID 5B EVAP
TID 5C EVAP
TID 71 EVAP
TID 72 EVAP
TID 73 EVAP
TID 74 EVAP
TID 75 EVAP
TID 76 EVAP
TID 77 EVAP
scatgo1 likes this.
Old 22 Mar 2015, 10:57 pm
Default Re: New Toy
The readiness file is set in fault and yet no DTC?
I also do not see any way to veiw or accesse it either?
scatgo1 likes this.
Old 23 Mar 2015, 01:18 am
Default Re: New Toy
Yep. That's a strange one. My handheld says emission ready and there was no mil on while running the software.
Old 23 Mar 2015, 05:46 am
LionPT's Avatar
Default Re: New Toy
Can you take a pic of the screen that has the "Component Id $00 TID $16 - Manufacturer Defined 4 17 N/A Fail" error.
Old 23 Mar 2015, 11:32 am
Default Re: New Toy
them mode 6 hex codes are a bitch to locate...I got software for my laptop with elm 327 connector....
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
