All of the PT turbo engines are basically the same. There are some minor differences such as the plastic intake manifold that was used from 2005 and up and some minor vacuum hose differences. But the blocks and heads should be interchangeable to the best of my knowledge. As long as you have the complete original engine, you should be able to change out any external parts that are different.
The real differences are in the non-turbo engines. Of course, the non-turbo engines are not interchangeable with the turbo engines. And the 2001 and 2002 non-turbo engines are unique due to the type of crankshaft sensor and crankshaft sensor wheel used. So they are not compatible with the 2003 and newer PT's. The forum member to confirm this with is UpTownSport. He knows an awful lot about the the heads and blocks used in the PT Cruiser. You should be able to send him a PM.
![]() Last edited by Handy_Cruiser; 24 Mar 2015 at 12:58 pm. |
From what I've read, the long block (head and engine block) are the same. But the intake and exhaust manifold and a few other external items are different. Again, if you have the original engine for the externals, they will likely interchange.
SRT4 Engine (in a PT Cruiser) ![]() PT Turbo Engine ![]() However, it is possible that the cam sensor magnet will be at a different clock position. To check, you would have to remove the sensor magnet from your original engine and note the position of the dowels while the engine is at TDC. Then do the same with the SRT4 engine and see if they are the same. If different, there's a couple of ways to deal with it. You likely would want to check this with a PT turbo donor engine as well. It's been reported that some PT turbo engines used the Neon magnet position rather than the usual PT position. ![]()
![]() Last edited by Handy_Cruiser; 24 Mar 2015 at 02:09 pm. |
![]() Quote:
![]() Quote:
While this issue has been reported with PT's and SRT4's, I'm not so sure it's common at all. And it may not even be an issue on these 2003 and up 2.4L engines no matter the configuration. I don't have access to enough 2.4L engines to check this out for myself. So I have to depend on the advice of others for this one. But, it bothered me enough to check the dowel hole position on the donor cams used to grind my performance cams. And I would still recommend checking this anytime a 2.4 engine is swapped.
![]() Last edited by Handy_Cruiser; 24 Mar 2015 at 04:03 pm. |
Thread Tools | |
Display Modes | |
Remove & Replace engine oil cooler on a 2004 PT turbo? | johnchilders | General Turbo Discussions | 5 | 03 Jan 2014 03:29 pm |
2004 non-turbo engine mounts replaced | cookj | Tech & Performance Forum | 1 | 22 Oct 2012 04:31 pm |
2004 Turbo Engine noise in car | VOETOM | Tech & Performance Forum | 3 | 21 Mar 2012 10:01 pm |
ENGINE HARNESS 2003 2004 2005 pt cruier turbo $125 | turbogodstoyscom | Classifieds: For Sale/Trade | 2 | 29 Sep 2011 10:06 pm |
2005 non turbo engine work in a 2002? | darkostoj | General PT Cruiser Discussions | 2 | 01 Oct 2009 08:30 pm |
