Water leaking
Old 23 May 2015, 01:30 pm
Question Water leaking
2001 PT Cruiser
Had water pump and timing belt changed in Feb. Starting last week, water is leaking out of car. I open radiator and fill it with water and it comes right out about 5" down from radiator spout. Car also is running bad.
Any ideas?
Old 23 May 2015, 02:38 pm
Default Re: Water leaking
The only thing in that area is the base of the radiator fill spout, sometimes they crack or warp, the water pump, or the on the back side of the water pump mount there is a tube and piping that carries the coolant to the heater.
The power steering pump might be in the way of a clear view to see whats leaking.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 May 2015, 03:33 pm
will check....maybe a hose???
Old 23 May 2015, 04:36 pm
my best guess would be the thermostat housing.
2016 Kia Soul Plus Black
Old 23 May 2015, 05:42 pm
The leak doesn't explain the running bad. Unless you have a bad head gasket.
You might have 2 issues?
The thermostat housing could be leaking or cracked, Upper hose leaking, or the gasket between the block and the housing that the thermostat goes in to could be bad. Another thing to look at could be the the temp sending unit could be cracked. It's under the thermostat housing.
Wipe it off good and look closely to see if the water is coming from the thermostat area or from behind the timing cover. I have a radiator pressure testing setup. It goes on in place of the radiator cap and I can pump the pressure up to check for leaks. Autozone (if you are near one) might have one as a loaner tool.
Good luck. Hope it's simple!
Old 24 May 2015, 12:47 pm
Yep, changed thermostat. Water problem is now fixed.
Still running bad. Looked at it again today and looks like maybe EGR not hooked up?
Water leaking onto floorboard drivers side JolieCruiser General PT Cruiser Discussions 22 25 Jul 2015 07:48 pm
Water leaking from the bottom micdhack General PT Cruiser Discussions 8 02 Jun 2014 07:26 pm
06 pt (A/C) leaking lots of water from the firewall at the ac inlet to interior steveohb Tech & Performance Forum 7 14 Jul 2009 08:00 am
Water pump leaking at 38,000, have a question... Rumble Tech & Performance Forum 8 30 Dec 2008 07:12 pm
water leaking six0fourgirl Tech & Performance Forum 18 02 Oct 2008 09:51 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
