First Off, Let me say If I posted in the wrong area, Kindly tell me, and I will attempt to figure out where I need to move my post.
I am the owner of a basic 2007 PT Crusier. The other day, While on the way home, something happen to the car. I lost control of the brakes and tapped the back of my soon to be mother in law van. There was no damage to either vehicle and it was a tap like as if someone tap you on the shoulder. Well The car started having issues. I got it towed to the house, and did a more routine inspection. I've found something that I am not clear of what it could be, thus the main reason I am posting here. There is a bar that goes from the transmission/gearbox to the driver's side tire that is covered in black sludge. I am not sure what the technical name is for it, but I believe it to be the equivalent of a drive shaft since it makes the wheel spin. I am trying to find the technical name of the bar so that I can see about getting it replaced. When driving, it also has a loud knock sound coming from the gearbox I think Also, If anyone could advised what could be causing the shifter to do the following: The Shifter itself will not go into Park or Reverse. It won't go above Neutral, yet on the dashboard it says the car is in Park. When the Shifter is in Drive, the Dashboard says reverse(and will go in reverse). When the shifter is in 3rd, it acts like neutral, and when the shifter is in 1st, it acts like drive. So a better Idea: Dashboard - Shifter Park -------- Neutral Reverse ---- Drive Neutral ----- 3rd Drive ------- 1st Thank you all for the help, and I would like to apologize for my ignorance ahead of time. |
I am suggest you might have at least two problems.
I would suggest checking to see if your CV booth is torn and all the grease is leaking out of it. This grease might have gotten into your brakes and possibly caused the problem with your brakes. I would suggest that if the CV booth is leaking to check the CV joint and see if it needs replacing. If you have not introduced yourself to the forum I would suggest you do and say a little about yourself and your PT Cruiser. Last edited by ptcruisersteve; 24 May 2015 at 08:57 pm. |
Tags |
2007, cruiser, driveshaft, gearbox, transmission |
Thread Tools | |
Display Modes | |
Transmission Issue | GTLOZER | Tech & Performance Forum | 1 | 16 Feb 2014 10:37 am |
Transmission issue!! | gramicci | General PT Cruiser Discussions | 13 | 06 Sep 2013 09:27 pm |
transmission issue?? | mdskinner731 | General PT Cruiser Discussions | 8 | 18 Mar 2013 03:19 am |
Transmission Issue | Dhycin | Tech & Performance Forum | 4 | 15 Jun 2010 04:23 pm |
Transmission issue... | MDCruiser | Tech & Performance Forum | 10 | 06 Mar 2006 08:14 pm |
