Just sold another one of my cars and figured I'd give my 2004 PT Cruiser GT an ignition tune up since I have no idea when it got one last and it has a little bit of a rough idle I'm hoping to clear out.
I've done some digging on the forums and couldn't find much on the Davis ignition coil other than talk about plug gap. Anyone have any experience with these Davis ignition coils? Compared to MSD coils Davis outputs 45k volts as opposed to 36k. I know people say to just leave the stock Mopar coil on there but I figure it can't hurt to do all new plugs, wires, and coil in hopes of having a smoother idle. Any tips or recommendations welcome, curious on the Davis coil as I've never used them but I've been happy with my MSD products. Last edited by FlyinPurplePeopleEater; 25 May 2015 at 05:56 pm. |
I would suggest checking all your vacuum lines including the one going to the brake booster. Check for cracks and pin hole leaks.
If a stock coil draws 1 amp per 1k rpm, it would be safe to assume a coil with twice the power would draw twice the power. It gets its power from those three little wires that feed it. You may end up taxing other components over time and you'd never even think that was a contributing factor.
Another thing to think about is wider gaps and stronger spark energy will erode the plugs electrode faster. Things like "more volts" are great for advertisements, but It's not like you're going to go bragging your coil has more volts at a car show. If you like MSD I'd recommend you just stick with them, as it's already overkill. Not a mechanic, but I'm pretty good with electronics. I dug into this recently because my wide gaps were wearing out my cap and rotor too fast on my mustang. Seemed I was replacing them with every oil change Last edited by rob342; 25 May 2015 at 06:54 pm. |
I do like the red color of MSD, if I remember right for the color to HP conversion red is about 50 extra HP.
![]() Now only if it was red and had flames on it I would buy two for my car. I wasn't too sure how the volts affect actual performance and kind of guessed it was more of an advertisement thing than anything else. I will have to look into an oscilloscope as I'm not too familiar with them but I've found there is a lot more science behind plug gap and coil selection than I thought, I'll have to do some more digging and research. |
![]() Quote:
Accel makes a nice yellow coil if you want to be different from the more common red and black guys.
Or just paint it the color you wish. Just insulating anyway. May need to avoid metallics.
![]() Quote:
I got ya' covered on the flames and high voltage coil. You will just need to make a few modifications to your ignition system and make sure to run solid copper spark plug wires. ![]() ![]() ![]()
![]() Last edited by Handy_Cruiser; 26 May 2015 at 11:13 am. |
Thread Tools | |
Display Modes | |
screaming demon coil new gap? | 3rcruiser | Tech & Performance Forum | 19 | 30 Sep 2014 07:51 pm |
screaming demon coil go or no go? | campuscolt65 | General PT Cruiser Discussions | 18 | 01 Jun 2010 02:54 pm |
Screamin' Demon Ignition Coil... | Silvercruzr | Tech & Performance Forum | 7 | 15 Jun 2005 08:13 am |
screaming demon coil plug gap | GTCOOL | Stage Turbo Kits | 1 | 10 Jun 2004 07:15 pm |
screaming demon | skeeter1620 | Turbo Performance | 8 | 19 Jan 2004 11:35 am |
