I have another no oboe question....
I have the Amber ABS dash light on all the time... Which is kind of odd, as according to my VIN, my cruiser doesn't have ABS brakes! Has anyone ever run into this, at all? Thanks again! Alynn
It is good to have an end to journey towards; but it is the journey that matters in the end. ~Ursula K. LeGuin 2005 PT Cruiser (Base Model) Convertible - 5 Speed |
![]() Quote:
![]() Quote:
![]() For the OP, does your PT have this under the master cylinder? You may need a flash light to see it. ![]() PS: If it has ABS, you may need a OBDII scanner that reads ABS in order to root out the issue. But many folks end up just having a bad wheel sensor or broken sensor line. Inspecting the lines and cleaning all four sensors is often a good thing to try first.
![]() Last edited by Handy_Cruiser; 28 May 2015 at 06:27 pm. |
![]() Quote:
![]() ![]() ![]() ![]() There is no Traction control button..... I just saw the question about the ABS pump. I'll have to check it tomorrow after work, and will report back! I am going to replace the ignition lock cylinder this weekend (my other thread....), would replacing that clear the ABS dash light? My Parking brake light also won't clear... Thanks, agiain, and this is a fun place to "learn things"! Alynn
It is good to have an end to journey towards; but it is the journey that matters in the end. ~Ursula K. LeGuin 2005 PT Cruiser (Base Model) Convertible - 5 Speed Last edited by Alynn; 28 May 2015 at 09:12 pm. |
I would suggest checking the switches for the brake and the emergency brake to see if they are working properly.
Handy, I don't see an ABS pump under the master cylinder. ( Stupid Question Alert...- The brake fluid resovoir sits on top of the master cylinder right? ~~insert embarrassed smiley here ~~
Thanks! Steve: will be checking those switches tomorrow and will report back! Thanks for all the great help! Alynn
Update----
I looked at the parking brake switch, and the copper parts look rusty, like something spilled on it. Will have to order as Auto Zone doesn't stock it. Question, though... Does the wire side only connect to the switch with one connector? I should have taken a photo when I had the seat out.....????? I will replace it and then go from there... Unless there are other ideas... Thanks, Alynn
It is good to have an end to journey towards; but it is the journey that matters in the end. ~Ursula K. LeGuin 2005 PT Cruiser (Base Model) Convertible - 5 Speed Last edited by Alynn; 30 May 2015 at 10:55 am. Reason: To add question. |
I took "Pixie" in to my local tire shop to have the parking brake checked, to see if it is stuck. The Good News? Not Stuck! Yay!
Bad News? 1 Leaking rear cylinder, 2 rear rotors out of round and 1 front (left) bad wheel bearing!! However, I did confirm - NO ABS! So, on Saturday, I will be pulling off the knuckle, taking it, and a new bearing into the local shop to have the old one removed and the new one pressed in, and then putting it all back together. I need to pick up an axle nut socket, ( don't have one that size), and a set of crowfoot sockets, for torquing the tie rod, and the bearing. I've done a lot of research, including this thread from 2014, Is this mechanic an idiot?... or am I missing something. And I found it quite interesting, that in my Googling, I found the same video as in that tread, and it explains the procedure vey well. Please wish me luck. I'm trying to learn to take care of as much as I can. It's fun, as well as saving a buch of money. Quote for rear brakes, and front wheel bearing was over 800.00. I will be taking care of the rear brake issues after my next paycheck (and buying groceries!!!) After rear brakes: wires, plugs and valve cover gasket and oil change..... Do you all think this is doable, by a 50+ year old lady hippie??? Thanks again! Alynn ![]()
It is good to have an end to journey towards; but it is the journey that matters in the end. ~Ursula K. LeGuin 2005 PT Cruiser (Base Model) Convertible - 5 Speed Last edited by Alynn; 11 Jun 2015 at 06:02 pm. Reason: Additional info! |
Thread Tools | |
Display Modes | |
Dash Mod for 2nd gen Cruiser | Cruiszr | Interior Accessories Forum | 2 | 02 Jun 2012 06:32 am |
01 PT Cruiser Dash Air Vent Problem | deklar | General PT Cruiser Discussions | 4 | 16 Sep 2010 07:17 pm |
Cracked PT Cruiser Dash Cover | Benwin82 | Interior Accessories Forum | 8 | 15 Sep 2010 06:06 pm |
New Dash in old Cruiser? | thatsmrjptou | Interior Accessories Forum | 4 | 21 Sep 2009 03:55 pm |
Dash parts for '02 Cruiser | mopar_man | Classifieds: Want To Buy | 1 | 14 Aug 2009 01:49 pm |
