Has anyone replaced their transmission fluid with B&M Trick Shift, or similar "performance" type transmission fluid?
Also, transmission filter change....... Is there a better filter than the stock one that comes on our fine autos? I am interested in the best filter I can find that will provide max flow while continuing to provide required filtration. Also, is there a deep trans or other trans pans available? I had replaced the trans pan on a TH400 with an aftermarket pan that incorporated cooling fins and thru tubes to provide additional cooling. I drive mainly at highway speeds over 1400 miles a week, every week and summers here in TN tend to be very hot. Any additional cooling I can provide for the transmission will prolong its life and reduce the potential pain in my pocket. Thanks, Scott Harris 2003 Black Touring Edition - cold air intake and MagnaFlow muffler |
I have used B&M Trick Shift in the past in TH400 and TH350 transmissions with great success. I just wonder if it would be compatable with the auto trans in the PT? Anyone know??
How difficult is it to change the transmission filter? Thanks, Scott Harris 2003 Black Touring Edition - cold air intake and MagnaFlow muffler [8)]
2003 Black PT with ghost flames, Magnaflow exhaust, cold air intake, lowered, chromed and totally underpowered.
only use chrysler fluid or valvoline maxlife atf+4
they have the special friction modifiers that the chryslers need.
www.cardomain.com/id/rallydrock |
B&M Trick Shift only meets or exceeds Mercon or Dexron III requirements and is NOT recommended for electronic controlled transmissions. As mentioned before, you need to use ATF+4 or its equivalent or you may void your warranty and experience strange transmission shifting behavior.
2002 Almond Pearl Limited Edition 27K It\'s nice to be important, but it\'s more important to be nice. http://sci-fi.ptenthusiasts.net/
DO NOT USE ANYTHING OTHER THAN MOPAR FLUIDS. i have been rebuilding transmissions for 7 years at a dealer. these transmissions do not like any other fluid. atf+4 is 100,000 mile service life though i don't recomend this that is what the book says. myself and all other tech will normally recmend it at 30-45,000 keeps things working well.
\'03 pt gt s1 mopar bov auto patriot blue 1925 modle t pulling truck w/864hp 673ft/lb 2002 harley, 1998 zrt 600 cat http://cpatrucks.org/members/endres.html |
i used trick shift on my mazda mpv minivan and it worked pretty good. without it, my rev limiter would kick in before the car would shift gears. but i ended up destorying that transmission
Have you thought about using the air to oil transmission cooler as used on the turbo engined cars? Technicaly it could be connected inline with the stock cooler (inside the radiator). Take a look at one on any turbo engined PT.
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Codes | skylight | Tech & Performance Forum | 6 | 07 Apr 2007 02:19 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| Shift balls for manual transmission..... | thegoldpt | Tech & Performance Forum | 6 | 11 Nov 2005 03:16 am |
| Auto Tranny will shift even if in 1st gear? | BumperBob | Tech & Performance Forum | 4 | 07 Apr 2005 11:07 am |
