After replacing the IAC and the Ignition Switch, our loss of power seemed resolved and I was left with a P0420 code only. I have been researching and trying to determine the best course of action....
Tonight, we took Pixie for a spin, and all of a sudden we had intermittent loss of power PLUS the tachometer and the speedometer stopped working. Limped along to Autozone to have codes read. Here is the list, plus what I think my next steps should be..... P0420 Catalyst System Low Efficiency P0032 HO2S Heater Circuit High Voltage Bank 1 Sensor 1 P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2 P0501 Vehicle Speed Sensor Range/Performance U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module U110C NO FUEL LEVEL BUS MESSAGE P0508 Idle Air Control Valve Sense Circuit Low Replaced IAC Last Saturday What I think I should do: Check for Vacuum leak - due to the fact that I just replaced the IAC with a brand new one. Replace both O2 sensors Replace VSS After that, I am at a loss with respect to the U0155 and the U110C Does any one have any ideas, and am I on the right track so far? Does it sound like I have a bad instrument cluster? Boy, this is crazy. I seem to get one code/problem clear and then -wham- more codes/problems crop up. I do have to say that I understand that I bought a 10 year old car, and to be honest, we only paid 2,300.00 for it. I knew there were going to be things to fix. I am not a mechanic, however, I am mechanically inclined and not afraid to try to figure things out. I had planned to replace the plugs and wires this weekend, but I think I have bigger issues to deal with first. We really love this car and I want to get it running in tip top (and especially SAFE) condition myself if at all possible. I love having this forum to come to. You all have been very helpful, so far and I expect nothing less for the rest of my PT adventure. I'm sorry that this post is long, but I hope that it has been fairly readable and understandable. Thank you again for all of your help and understanding!!! Alynn
It is good to have an end to journey towards; but it is the journey that matters in the end. ~Ursula K. LeGuin 2005 PT Cruiser (Base Model) Convertible - 5 Speed |
I would suggest checking your battery. Have a battery load test done. If the voltage gets low enough it can give you different error codes.
Check the battery cables. Make sure you are getting good contacts. You probably have at least two problems. One is your catalytic converter might be clogged or not working properly. How long does it last before the P0420 error comes back on? On the other error codes I feel you might have a weak ground somewhere. Check the ground for the Instrument Cluster. Check your ground wires under the hood. |
![]() Quote:
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
Steve:
I had the battery checked at O'Reilly's about 2 weeks ago, right after the loss of power happened. I'm not sure they "load tested" it, but he did 'check' it and the meter/tool said that the battery was good. It was about 100 miles before the CEL came back on from the last time I cleared the P0420 code last Saturday. I have read several places on the forum that the P0420 could possibly be caused by the 2 o2 sensors. Any thoughts on that train of thought? Also, if it is the catalytic converter, will it hurt the engine to run it with the code still keeping the CEL on? I'm not too familiar with the electrical/wiring aspect of a car, but I am willing to learn. Could you explain the best way to check the ground wires? I have a multi-meter if that is a useful tool for this purpose. I don't mean to sound dumb, but with cars, I kind of am..... But I want to learn to do as much as I am capable of, I just have to work the learning curve.. ![]() Thanks for taking the time to help!! Alynn
LionPT:
That sounds doable. I will be working on Pixie tomorrow and will report back. I have had the battery disconnected (disconnecting the negative cable only) several times in the past 2 weeks, fixing problems, and clearing the codes. It is possible that I've disturbed the ground connection in some way. Thanks, and I will let you all know what I find. I am also going to do the vacuum leak test to see if I can find a leak, to clear up the P0508 code, as well. Once these are cleared up, I will the work on replacing the O2 sensors and the VSS if those codes show back up. One fix at a time to keep organized and not get overwhelmed. Also, from working with computers, you must not try more than one solution at a time, or you end up not knowing what the actual problem was, or which solution resolved the issue.... ![]() Alynn
UPDATE!
I checked / cleaned the battery ground wire, no rust, no visible damage. I also replaced the ignition switch, as I had advice from rob342 that this could be part of the problem. I did the vacuum leak test using carb cleaner, no revs, or change in the engine running at all. We drove it about 12 miles yesterday and today, and the CEL comes back on. I did the "key dance" and only had the p0420 code show., so far. One thing I missed from ptcruisersteve though, is checking the instrument cluster ground. Can you tell me where to find it? I am assuming it is behind the cluster, which involves removing the dash? Thanks for keeping up! Alynn
I will get back to you on the location of the Instrument Cluster ground wire.
The link below seems to have the same approximate issues as yours did. http://www.allpar.com/forums/threads...r-dies.151900/ Last edited by ptcruisersteve; 09 Jun 2015 at 01:33 am. |
I am still looking for access to the ground wire. I have not found the thread that showed the ground wire. Maybe someone else knows.
I appreciate it. I will be driving her to work today, kind of a test to see if changing the ignition switch cleared the problem. I drive 20 miles each way, so we'll see.
Have a Great Day! Alynn
Thread Tools | |
Display Modes | |
My Continuing Saga Of Owning a PT Cruiser. Got codes now, need advice again... | adz20mark | Tech & Performance Forum | 22 | 16 Jan 2015 03:58 pm |
Error codes 301 and 441 | kowalski4 | Tech & Performance Forum | 0 | 10 May 2012 11:39 pm |
Error Codes Error | lilcruiser | Tech & Performance Forum | 2 | 10 May 2012 05:34 am |
The overheating saga continues... | Mulligandog | Tech & Performance Forum | 8 | 27 May 2011 11:13 am |
The Saga Continues | CruisnHskrJim | General PT Cruiser Discussions | 4 | 05 Jun 2008 10:21 pm |
