First of all, hello all! I have had this Cruiser (2004, auto, not turbo) for about 6 months and it is now going crazy. Coil, fuel pump, and main computer have been replaced. Problems started a couple of weeks ago with the radio working sometimes and not other times. Then it started cutting out the engine at 3400 rpm while driving. Even if you are in park with the pedal floored, the tach will bounce between 3400 and 3000 rpm. It will not go over 3400 under any circumstances. Then a few days later it started doing the same thing at 2400 rpm. So now, sometimes it does it at 2400 and sometimes 3400. I can pull it over and shut it off and sometimes it will go back to 3400 when I restart (less of a pain to drive). Here is the weird part. When it is cutting out at 3400 rpm, the horn and cruise control will work. When it is cutting out at 2400 rpm, the horn and cruise control will not work. What in the world is going on? It can't be the clock spring because then the airbag light would be on. And what would a cam or crank sensor have to do with the horn and cruise control? Could I be getting a false code and the problem really be the computer? The codes are P0442 (evap), P0456 (evap), and P0344 (camshaft position sensor circuit intermittent). And, of course, the radio still cuts in and out.
I would suggest that you start fixing the problems that the PT Cruiser is telling you with the engine trouble codes first.
I would start with checking your camshaft wires and checking to make sure its making good contact with the camshaft sensor. If that is okay I recommend you replace the camshaft sensor. It can cause the engine to cut off at around 2500 rpm. On the EVAP issue I would suggest first checking your gas cap. Make sure you are getting a good seal on it when you put it on. You might need to check your EVAP system to find out what is wrong with it. Last edited by ptcruisersteve; 13 Jun 2015 at 06:22 pm. |
Yes, I saw that thread, but it did not include some of the same issues, like the operation of the horn and cruise being tied to the max rpm of the motor. Makes me think it could be a computer issue, but not sure. I changed the computer out because of a previous issue, but I guess the new one could be faulty.
![]() Quote:
![]() Quote:
I have the same intermittent radio cutting out on 03 Pt ...adjust tilt or push on the steering wheel fixes it every time..I suspect the harness in mine ,but unless it completely stops working I will not worry about it. I suggest you remove 2 Phillips screws on cover around column and move your harness slightly if the radio cuts out again just for giggles to see if it fixes that problem.
I'm a little perplexed about it "cutting out" at 3400 RPM if you are at idle yes it will cut out as it has a Rev Limiter . The codes listed for the cam position sensor have you replaced the sensor yet? You might start there I have replaced mine a couple of times as well as on my 03 neon . Cheers ![]() |
![]() Quote:
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
Yes to ignition switch sometimes I jigle the key and radio starts working so again as long as I can get it working I will just live with this just a little quirk of my PT
Tags |
camshaft, cruise control, horn, radio, rpm |
Thread Tools | |
Display Modes | |
this MONSTER pt cruiser is insane!!!! 1 seater drag racer. CHECK THIS OUT | PtBruiser714 | Tech & Performance Forum | 0 | 15 Jan 2014 03:37 pm |
Don't like the GT. Am I insane, or what?! | Gru | General PT Cruiser Discussions | 30 | 05 Apr 2013 04:02 pm |
Were the designers insane? or just high :-p | pluminator | General PT Cruiser Discussions | 20 | 24 Jul 2012 12:50 pm |
Im about to go insane. | Turboguy85 | Tech & Performance Forum | 2 | 11 Sep 2011 10:57 pm |
Zaino - The Shine is Insane-O! | Scarlet2003 | The Detail Shop | 1 | 08 Nov 2008 06:45 pm |
