well to begin, i have a 2002 pt cruiser limited edition which comes with the gray transponder key
a few days ago, i accidentally broke my key in the ignition while trying to start my car. luckily, i was able to remove the broken piece from the ignition without damaging it at all. right after that, i attempted to start my car with a non transponder key copy that i had made quite some time ago not knowing that doing so would trigger the SKIM immobilizer. the car started and then died 2 seconds later, and did this 3 times. now, the car wont turn over at all, the little red LED on my dash is blinking, and the stealership is telling me they want $120 to "possibly" correct the issue. does anyone know of any way to reset the SKIM module or bypass it altogether? any advice would be greatly appreciated. thanks alot |
![]() Quote:
The sentry key security system will totally disable the car if someone tries to start it with the incorrect key 3 times where the PT Cruiser will start and then die.
I would do what Busted_PT suggests in post #2. If that doesn't work then do the suggestion below. I have not done this but I would suggest trying this method. To reset the system requires putting a working skim key (Put the head of the broken transponder key, next to the head of the non transponder key put them together with a rubber band) in the ignition to the on position (not starting), and leave it on for an hour. I would strongly suggest hooking up a battery charger so the battery does not go dead. See if that works. |
![]() Quote:
![]() Quote:
During "my fun" finding the PCM was bad, the mechanic removed the SKIM to test the 2 sec run several times. Once he put it all back together it started fine. |
![]() Quote:
Explains why you had fun finding the pcm. They put them on the firewall in 03 I believe. Instead of the end of the frame rail on your's.
![]() Quote:
The "fun" was chasing down my not starting to the PCM, which since changed has been faultless. Last edited by VOS; 16 Jun 2015 at 10:37 am. |
Tags |
immobilizer, security, skim |
Thread Tools | |
Display Modes | |
Immobilizer | commosutra | Tech & Performance Forum | 24 | 14 Jan 2015 03:10 am |
Key SKIM Immobiliser Starting Issue - Where to start | bluebossa | Tech & Performance Forum | 7 | 10 Aug 2014 06:23 pm |
02 PT WONT START | sgtwsky | Tech & Performance Forum | 2 | 15 Jan 2014 05:39 pm |
Help needed: 2007 PT Won't Start: Alarm / RKE Module - SKIM Key Issues | bluebossa | Tech & Performance Forum | 6 | 05 Oct 2013 11:55 am |
02 wont start | anthonye559 | Tech & Performance Forum | 5 | 20 Sep 2011 11:44 pm |
