Help with removing Steering wheel cover and airbag in '06 NA PT
Old 02 Jul 2015, 08:44 am
Default Help with removing Steering wheel cover and airbag in '06 NA PT
I'm trying to install a cruise control kit in my '06 NA PT.... however, for the life of me... I can't get the steering wheel cover and airbag off.... specifically, when EVERY set of directions tells me that I need to find the three access holes on the back of the steering wheel cover, and then to take a short flat-head screwdriver and press in and twist the wire holders off...
But...
There are no clips, no wires, etc to actually move ... Unless I'm missing something... But every diagram always tries to show you how to remove everything, but it clearly shows that the steering wheel is already taken off...
Some other diagrams actually say to remove the torx screws on the back of the steering wheel to remove it... but you can access these without literally taking the entire steering column apart first...
What am I missing? Where am I going wrong? Any help with this is greatly appreciated... because this car is actually really starting to grow on me.
Aside: I bought the car from my grandparents, didn't expect to keep it for more than a year, and i'm starting to REALLY love it. Which is why I'm trying to fix it up.
Old 02 Jul 2015, 01:56 pm
Ray_Dockrey's Avatar
Default Re: Help with removing Steering wheel cover and airbag in '06 NA PT
They are a pain but the clips are there. All you have to get is the two side ones. Once those are popped then you can swing the air bag down and the bottom clip will pop.
I have done it several times and its never easy. Pressing down on the air bag (honking the horn) can take a little pressure off to help unclip them but i always just brute force them. They are seriously a pain.
Look at the top picture of this site. It shows the clip.
http://www.justanswer.com/dodge/3jm6...html#re.v/175/
Old 02 Jul 2015, 02:05 pm
What do you mean by "I always just brute force them"? ... as in.... just yanking on the cover directly?
Old 02 Jul 2015, 03:07 pm
Uh, no. The metal hoops are really, really tight. You have to move them over enough to get them to unhook from the metal hook. You can push down on the airbag to relieve some tension but then you can't feel when they unhook.
So I just leave the airbag as is and twist for all its worth till they snap off.
Old 22 Sep 2015, 12:05 am
Hate to revive a dead post, but was your car prewired? If so, did you already have wiring and connector for the control lever (on/off/set/res/cancel switch)?
Or did you have to wire it yourself?
'06 N/A 2.4L 5 M/T
PT Logo Steering wheel cover? dom92 Interior Accessories Forum 3 23 Sep 2013 08:12 pm
wheel skin steering wheel cover chintzgirl Interior Accessories Forum 0 23 Oct 2010 08:05 pm
Steering wheel leather cover? rcalzadilla Interior Accessories Forum 4 02 Nov 2009 04:56 am
Steering wheel cover Striker Interior Accessories Forum 2 08 Apr 2006 07:33 pm
"Wheelskins" steering wheel cover... Gary04GT Interior Accessories Forum 2 10 Nov 2003 11:02 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
