New Ignition Switch - No Accessory Power
  • 1 Post By Alynn
Old 02 Jul 2015, 12:09 pm
Default New Ignition Switch - No Accessory Power
I recently replaced my ignition switch and lock cylinder, and just realized that when I turn the key to the "accessory" position, there is no power. Only when I go to the " on/run" position, just before cranking the engine ...
Any thoughts???
Thanks,
Altnn
It is good to have an end to journey towards; but it is the journey that matters in the end. ~Ursula K. LeGuin
2005 PT Cruiser (Base Model) Convertible - 5 Speed
Old 02 Jul 2015, 09:09 pm
Default Re: New Ignition Switch - No Accessory Power
Did you replace the ignition actuator when you replaced the key cylinder?
Does the chime goes on when you open the door with the key in or out?
Old 03 Jul 2015, 08:05 am
I did not change the actuator pin, and the door chime sounds with the key in but not when it is out....
Could I have gotten a bad switch?
We have NOT had any power loss issues since I replaced the switch.
Thanks,
Alynn
Old 03 Jul 2015, 11:31 am
Because Trump
Old 03 Oct 2015, 11:39 am
Default Re: New Ignition Switch - No Accessory Power ~ SOLVED
Just a quick update.... I replaced the actuator pin and now I have accessory power!!
Thanks to everyone for your suggestions!!
Alynn
Gkon likes this.
Old 10 Oct 2015, 03:27 pm
Update, Again.... Now no door chime with the key in, unless I phish hard on the key / lock cylinder and hold it. If I let go, no door chime!
I am so frustrated now!!
Alynn
Ignition switch lt4supr Tech & Performance Forum 10 21 May 2016 06:28 pm
Ignition switch?!?! Lolo376 Tech & Performance Forum 19 23 May 2014 11:20 am
Ignition Switch BMAC1206 General PT Cruiser Discussions 10 22 May 2012 03:27 pm
accessory power in the 02 BShashinka Interior Accessories Forum 0 03 Apr 2012 09:36 pm
accessory power lead urimashe Sound and Security Forum 17 21 Dec 2010 11:18 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
