Roaring from front
Like Tree4Likes
Old 03 Jul 2015, 07:57 am
Default Roaring from front
I have a 07 cruiser with 189k miles. Have replaced both front wheel bearings previously, and just replaced passenger side cv axle. After a test drive, the roaring is still present. Thoughts.
Old 03 Jul 2015, 08:13 am
Default Re: Roaring from front
swerve right and left to see if it gets louder/quieter. you probably need new bearings again. i change them on a malibu every 5 months because i bought them from autozone
myckee likes this.
Old 03 Jul 2015, 09:17 am
If I turn right, the noise goes away. It's still there if I turn left. I just didn't think this roar sounded like a wheel bearing, but I can't rule it out.
Old 03 Jul 2015, 11:30 am
MJKnight's Avatar
Lot of those so called parts stores item are made in China..no quality control..
myckee likes this.
Old 03 Jul 2015, 11:41 am
Actually they all are made there now. The quality on some are very high. Nitro_PT has used a bran that has given him good service for him and his customers. But I don't recall the name right off.
Old 03 Jul 2015, 11:47 am
Well...this sucks! I would have thought the wheel bearing would have fixed it?? Loud dull roar increases with speed?? It was the passenger side front wheel bearing on our Tercel.
If the passenger side cv axle swap did not fix it?? Then maybe the sound is "actually" coming from the right side??
"Assuming" that is "not" the case, then the old part and the new part still have something in common?? First thought that occurs to me is maybe it's the bearing hub?? Maybe the race is worn??
Or easier still is maybe it's the wheels?? Try swapping the wheels front to back.
Couldn't hurt.
myckee likes this.
Old 03 Jul 2015, 04:57 pm
The TIMKEN bearings are made in USA. It says right on them. They are one of the best, if not the very best, bearing you can buy in my opinion.
That said, it could very well be the tires, so make sure you rule them out first. I had removed the winter tires from my 'new' car and put the summer wheels on, and the roar was unbelievable! I thought the bearings had done themselves in and even bought new ones. It turns out it was just the tires and a new set rid the car of the roar.
Old 03 Jul 2015, 11:48 pm
Smile Re: Roaring from front
I sometimes get a Roaring Sound from the passengers side of the car, too.
It usually happens when I drive quite fast .... it come from my wifes mouth.
3rcruiser likes this.
Old 04 Jul 2015, 11:38 am
NitroPT recommends SKF and Timken bearings depending on the application. These happen to be the two most expensive bearings but I prefer not to replace the bearings more often myself.
Also, is the ground wire still connected from the strut to body? The lack of a proper ground can lead to premature wheel bearing failure but I am never heard of anyone proving it. Is there any pitting on the ball bearing when you pull it out each time?
Old 05 Jul 2015, 01:42 pm
One clarification, when I mentioned that I had changed the front bearing previously, I should have included that it was 2+ years ago. Could the wheel bearing be bad again?
Passenger side wheel noise. (Howling and roaring) wishiwasyou333 Wheels, Tires, Suspension 6 21 Jun 2013 11:59 am
Roaring sound from front wheels, Bad bearings? LoboMX Wheels, Tires, Suspension 6 17 May 2011 06:50 pm
Roaring Sound PT_or_not_PT Wheels, Tires, Suspension 1 06 Apr 2010 09:24 am
LF Wheel Grinding/Roaring Noise gmiller Tech & Performance Forum 4 23 Mar 2008 11:57 am
Roaring noise from the rear when reversing?(FIXED) Ctown General PT Cruiser Discussions 3 17 Apr 2005 02:51 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
