2001 PT Cruiser A/C Recharge
Old 12 Jul 2015, 11:33 am
Default 2001 PT Cruiser A/C Recharge
A/C was working fine and then quite cooling. System had lost freon because of a leaking low pressure schrader valve. I replace both schrader valves and also replace all of the o-rings and gaskets with a kit.
Recharged system and now will not cool. A/C clutch engages for a couple of seconds and then disengages for about 10 seconds. Each time the high fan comes on. Radiator fan is working fine. I jumped the low pressure switch and it still does the same thing. Don't understand this. The high pressure line is cold and sweating, but the low pressure line is warm.
When clutch is cycling, these are the gauge reading I get:
-70 psi on the low side and 50 on the high side before clutch engages
-drops to 30 psi on low side and 25 on high side (then clutch disengages)
-repeats cycle
Wondering if the orifice in the liquid line is bad and wide open not allowing compression? Orifice is built into the liquid line hose from the lower side of condenser. Maybe the compressor is bad because I have never seen it go over 50 psi?
Replacing Cracked Radiator - Recharge A/C? Nvizn Tech & Performance Forum 2 07 May 2015 12:58 pm
Where is the lower port valve to AC recharge my 2001 mlpluess Tech & Performance Forum 4 14 Jun 2014 05:40 pm
03 vs 04 AC recharge - the definitive word? mmhendrie Tech & Performance Forum 11 17 Jun 2012 08:56 am
Hybrid Technologies Completes Lithium Rapid Recharge System for NASA PT Cruiser skylight PT Cruiser News and Rumors 0 01 Aug 2007 01:36 pm
Recharge AC? jmack General PT Cruiser Discussions 2 18 Apr 2005 06:58 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
