Tranny leak
  • 1 Post By rob342
Old 19 Jul 2015, 12:52 pm
Default Tranny leak
I changed the right side cv axle. I used a Advance Auto one that was supposed to be a perfect fit, but now I have a leak at the cv joint. I made sure to tap the axle in to fully set it and it appeared to seat fully. Any thoughts!
Old 19 Jul 2015, 12:59 pm
Handy_Cruiser's Avatar
Default Re: Tranny leak
This is a non-turbo model, right?
You may have damaged the seal when you replaced the shaft.
I would first remove the new shaft and compare to the old one if you still have it. Check the diameter and check the distance the shaft should be going into the transaxle housing and mark it on the new shaft. Then reinstall in the housing to make sure it is in far enough.
Also, while you have the shaft out, inspect the seal very well. You may see where it has been nicked or stretched out. These seals are only about $5 and not that difficult the change.
Old 19 Jul 2015, 01:33 pm
you should ALWAYS change the seal when you change an axle as they are cheap and it's quick. sometimes however, a new seal will leak with a new axle.
if you are still having issues with a new seal, read here. the fix is described in detail in post #5 CV Axle, Transmission seal leaks
just a heads up on removing the axle. i have a quicker way to do it that does not involve taking half the car apart. link: Passenger Front Axle Removal and Install
Old 19 Jul 2015, 02:20 pm
Thanks for the info. I'll remember this trick when I go back in to examine/replace the seal. I appreciate the input.
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
Tranny Fluid leak :/ need some assistance NicksCruiser Tech & Performance Forum 29 16 Oct 2012 09:23 pm
Oil Leak...replace tranny hose mstyler05 Tech & Performance Forum 2 11 Jan 2011 12:11 am
Tranny or something else? Kawizx9r Tech & Performance Forum 5 04 Sep 2010 02:57 am
tranny leak steve smith Tech & Performance Forum 1 17 Jun 2005 05:08 pm
