Hey all, I was wondering if anyone has a way of changing the cooling fan ON temp. I am running a 180 stat and would like to drop the ON to 195 or so, I think it is 220 by default.
2005 PT GT, Stage 1. |
![]() Quote:
![]() on my ford i run two of these(one each for low/hi): http://www.summitracing.com/parts/der-16759 however on your car you would be better off with the screw in sender due to the PT's thin radiator. http://www.summitracing.com/parts/der-16749/overview/ you might consider using ONE of those adjustable controllers that I used in conjunction with a small fan affixed to the front of the radiator like nitro used ![]() that is unless anyone has an easier way for you to do it.. nice thing about this route is you leave all the factory stuff alone and adjust temp with a small screwdriver. |
Thanks for the suggestion. I already had a fan available so I installed it today. Do you have your fan using a temp sensor?
![]() Quote:
yea the link is in my above post. the controller is a little black box. it has a small screw that you can turn to adjust hotter or colder. i like nitro's method better if you have the $$$ to pursue it. my car is a 1992 ford so that fancy electronic junk isn't an option. i feel spoiled just having the electric fan ![]() |
Yes, if you have a DiabloSport device, you can modify the range the stock fan operates on your GT. If you don't have a Diablo Sport tuner then you could send your ECU off to someone like Syked, and for a small fee he could modify this for you too. These are great options if you don't want to run an auxiliary fan and the extra wiring that it would entail.
Um...... really the first fan manual switch was nothing more than a universal 30amp relay kit and switch wired to the BIG wire on the OEM fan at the connector, 12 bucks on ebay! . The rest came later.
![]() IMHO it really is not the best investment to send a PT Cruiser PCM away to get anything done. The better investment is to get a Diablow Sport device. That way you can send DATA logs email have a CMR calibrate a file based off of your DATA logs and email them back to you. 45 seconds to upload and done deal! NO DOWN TIME waiting for the mail man to deliver the calibrator make adjustments and send it back to you. And if they are not accurate or exactly what you want ...well you get it! ![]() Even purchasing STAGE 1 MOPAR PCM is a little antiquated for Turbo Model PT's anymore. They are very conservative and the cost of one you could buy a DSP and do better PCM calibrations. I have already created 14 files now for different driving habits or conditions. To bad we currently can't share DS files. Well unless you are a CMR or have a device to copies them. |
Thread Tools | |
Display Modes | |
car temp goes hi wen AC on? | notime0075 | Tech & Performance Forum | 6 | 08 Aug 2013 05:14 pm |
aftermarket cooling fan temp control | samsonhusky | Tech & Performance Forum | 3 | 11 Jun 2013 09:34 am |
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in | rdvarona | Southeast PT Forum | 18 | 31 May 2013 09:14 pm |
compass and outside temp | 22dodge | General PT Cruiser Discussions | 11 | 20 Feb 2011 11:54 pm |
oil temp | brngrhd | General Turbo Discussions | 0 | 17 Mar 2004 12:53 am |
