A/C problem
Old 24 Jul 2015, 06:07 pm
Default A/C problem
Hi everyone! I have a 2002 cruiser. We had a leak in the low pressure hose, so we replaced that, the ac high pressure switch, the low pressure switch, and the system is charged to the proper level. I jumped the compressor so I know it works. The relay is also good. I am still not getting power to the compressor. What next??
Old 24 Jul 2015, 07:30 pm
Default Re: A/C problem
Does the compressor cycle or is it not coming on at all when you turn on the A/C?
If your low speed fan does not automatically come on when you turn on the A/C with the engine cold you need to check the low speed on the radiator fan. Check the wiring going to the radiator fan. Apply 12 volts to the low speed on the radiator fan and see if it comes on. Check and make sure the wires are connected to the A/C. The PCM needs to get communication from the A/C. Some members have found the A/C connector had fallen off not letting the PCM know that the A/C is on.
Old 24 Jul 2015, 08:09 pm
The fan comes on when I jump the compressor.
Old 24 Jul 2015, 08:36 pm
What is your current pressure on your high pressure side and your low pressure side.
Old 28 Aug 2015, 11:27 pm
Unhappy Re: A/C problem
How did you change the high pressure switch? I just cannot remove it.
Old 29 Aug 2015, 12:43 am
Additional troubleshooting should be performed to determine what the problem is before removing the high pressure switch. An A/C gauge set is required to determine what is really happening with the A/C system. Post what pressure you find on the low and high pressure sides.
Starter problem? Relay problem or others? postbeauty General PT Cruiser Discussions 3 22 Jun 2015 05:52 pm
2001 PT Auto Trans Problem and Engine Rev Problem johnwwjr Tech & Performance Forum 4 18 Apr 2015 10:00 am
AC problem became Overheating problem BilltheBrewer Tech & Performance Forum 1 23 Jul 2014 11:31 pm
Window problem and AC problem kaypriest Tech & Performance Forum 30 04 Jul 2014 07:42 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
