Hey Everyone...
I've been having some trouble lately with my 2006 PT Cruiser. Whenever I want to start the car, I have to crank it so hard that the key is starting to bend, and also it tends to not want to start in hotter weather (like right now here in Florida). A friend of ours says that it's either the Starter Relay or the Ignition switch. I'm hoping it's the relay since that seems like a much less complicated fix. I have a relay that we bought at autozone and I was wondering where the relay is located as this seems to be a serious point of debate between my wife and I, and also how to go ahead and change it. Thanks for all the help :-) |
I would like to try and replace the Starter Relay first, just to rule that out before I get that far in (and probably over my head) I just need to know where exactly it's located, since when I google I get a few different spots for it.
Some places say that it's the Tyco Relays that are near the top of the hood by the fender on the driver side, yet every parts store says that that is not the starter relay. |
![]() Quote:
![]() 2006 Touring Edition in Cool Vanilla...aka/Ghost |
I would suggest doing a battery load test first. The PT Cruisers are sensitive to voltage drops. Make sure you are not getting a battery voltage drop through your battery cables. Make sure the battery cable contacts are clean and making good contact. This is the first thing you need to do when you have starting problems.
The battery is good, we had a load test done a couple of weeks ago, and I just finished changing out the relay, but it still requires a lot of force to start, and I'm gonna try starting it again in the heat to see if there was any change at all.
when it comes to the ignition switch: is it something I can change myself (I'm not a professional mechanic, but I am good with directions and pictures, and I know when I'm in over my head and its time for a professional to do it), or is it something that has to be done by Chrysler? Last edited by Fryz2500; 01 Aug 2015 at 10:03 am. |
That doesn't look too hard to do, I'll report back and let you all know how it turns out :-)
I'd replace the switch. Sounds like you've got a thermal expansion problem in it and you'll never be able to find it. When it gets hot, it's losing the connection. When it cools off, it'll start. If you're bending the key, then you know it has to be in the switch. And it's not the tumblers in the key hole. It's the switch.
![]() Aspire to inspire before you expire. |
Thread Tools | |
Display Modes | |
Older member, long time lurker but first time poster today! | zanerwaner | Welcome New PT Cruiser Members | 18 | 20 Oct 2014 07:37 pm |
pt tries to start and does after long time cranking | woodslip | Tech & Performance Forum | 8 | 27 Oct 2012 03:02 am |
oil light on at start up beyound reg time. | srebik | Tech & Performance Forum | 10 | 29 Dec 2010 11:17 pm |
Time To Replace The Cruiser ? | richardc | General PT Cruiser Discussions | 6 | 09 Nov 2010 01:37 pm |
Won't start first time | Mike Radowski | Turbo Performance | 1 | 14 May 2003 02:34 pm |
