My wife's '02 cruiser died a couple of weeks ago, and the wouldn't fire when turning over. I am now trying to isolate the problem.
Which leads me to this question. I thought the alternator might be shot, so disconnected the accessory drive belt and took off the alternator drive belt. When I tried to start the car, it turned over, it didn't fire, but I got a little smoke/exhaust out from the air intake/throttle body. Any thiught? Should it normally start without the alternator and accessory drive belts? I did test the ignition coil pack, and it's measuring the proper primary and secondary resistance. Thanks for the help! |
![]() Quote:
If it doesn't turn, timing belt has snapped or lost the teeth on the belt.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
Most engines I've ever worked on will run without the drive belts. Of course, you don't want to run one very long without them. You need that waterpump turning to keep the engine cool! My dad and I used to start engines on the ground, out of the car. BUT, we always had a radiator hooked up to them.
Great little video. I forgot the water pump is driven by the timing belt on these engines. Last thing I had like that was a 3.0 Diamante. I had one heck of a time replacing that water pump and timing belt.
With the alt unplugged, you might have a problem there. Ask Nitro_PT. I know if you pull a battery cable off while running it will die. Belt off wont matter. But I think I started mine without the alternator. Just can't remember.
Thanks for the insights. I am going to get at the timing belt to be sure that hasn't broken or been stripped of any teeth. We'll go from there.
you are supposed to start and rev the car with the accessory belts off when changing the timing belt to verify it runs right. no belts, no alternator, no biggie.
![]() Quote:
how come? did you end up taking it ALLLLLLLL back apart to move it a tooth?
Thread Tools | |
Display Modes | |
Engine dies in 'drive', but revs in 'reverse' | Ford005 | Tech & Performance Forum | 3 | 29 Aug 2013 02:29 pm |
drive belts on a 02 cruizer | clark6 | General PT Cruiser Discussions | 6 | 20 Mar 2011 09:11 am |
Engine dies when put in drive not in reverse | TheAnt | Tech & Performance Forum | 11 | 15 Apr 2009 08:27 pm |
Drive belts | turbomangt | General PT Cruiser Discussions | 5 | 18 Apr 2005 07:07 pm |
Recall and drive belts | CREWZIN | General PT Cruiser Discussions | 5 | 12 Jun 2004 01:41 am |
