limp mode questions...
Like Tree3Likes
  • 3 Post By Gold2006
Old 03 Aug 2015, 03:53 am
Exclamation limp mode questions...
Hello fellow pt cruisers. I purchased a 2006 basic pt cruiser for my 16 yr old daughters 16th birthday....her very first car. and low and behold, 1 week later it goes into limp mode. my sister has done extensive research on the matter and I have questions of my own. using car MD, the codes were P0700, 0882 and 1603. I have not found what the 1603 is thus far. but of course the check engine light came on when this happened. I have taken it to the shop thinking it needed further diagnostics but now I am being told that maybe I should try some things before letting them go free for all on the car. when this happened, I checked the transmission fluid and it was 1/2 qt low. I put in fluid. at the time, I noticed that it had new fluid in it. I asked the dealer had they serviced the transmission and he said no (of course). So, here is what I've heard: if the proper type fluid was not put in, it could've caused this and can also cause serious tranny problems in the future, so I was told to have the fluid drained out and refilled with the proper fluid and to reset or wipe out the codes and that this would take it out of this mode. then if the problem happens again, at least I will know it is not due to the wrong fluid or low fluid causing the problem and then possibly the 'tcm, pcm' whichever is correct. does any of this sound right to anyone? I am disabled, on a fixed income and spent every dime I had on getting her a car. I simply cannot afford to just throw money at the car without knowing I am replacing the right parts. Any suggestions would be greatly appreciated. thanks in advance..., Sugar
Old 03 Aug 2015, 07:04 am
LionPT's Avatar
Default Re: limp mode questions...
P1603 PCM Internal Dual-Port Communication Failure
Old 03 Aug 2015, 10:50 am
There are a LOT of Mopars in junkyards with bad transmissions because people put the wrong fluid in them. MOPAR ATF+4 only! Dexron with an additive, type F will kill them. I actually argued with a guy at a trans shop about a 94 New Yorker I had. He said he'd do a change with Dexron with an additive and I told him "Oh, hell no you won't. Not on MY car." I even offered to go purchase the MOPAR fluid and he refused. So, I took it home, got a filter and a case of Mopar ATF+4 and did it myself. That took care of the problem I was having. As a side note, I noticed this shop had several Mopars sitting around waiting for service. I felt sorry for the owners.
Old 03 Aug 2015, 12:10 pm
Use of other than the correct fluid (ATF+4) WILL cause transmission problems including causing it to go into limp mode. At this point, without knowing what fluid is in the transmission, you have no choice but to flush all of the fluid out of the trans and replace it with ATF+4. This MAY solve the problem if the transmission has not been damaged by the wrong fluid or just plain wear and tear (don't know how many miles on your '06).
Old 03 Aug 2015, 12:12 pm
Amzoil synthetic Automatic Transmission Fluid
Change the fluid and filter at least at 50K miles intervals and a complete fluid replacement or properly performed flushing and filter fluid replacement at 100k miles.
IMO based on changing a few on customers PT the solenoid pack is a preventive maintenance part and should be changed at least at if not before the 100kmiles odometer reading.
If there is suspected transmission internal damage concern have the oil analyzed
http://www.blackstone-labs.com/transmission.php
Old 03 Aug 2015, 12:51 pm
NitoPT alerted me to your dilemma. Here are the fluids, filters and capacities for your car. Call me at 713-301-1872 for the best prices delivered to your door in 2 business days.
RestartBack
AMSOIL INC.
Auto and Light Truck Lookup
Go to MyAMSOILGarage™
2006 CHRYSLER PT CRUISER 2.4L 4-cyl Engine Code [B]
Lubricants & Fluids
Engine Oil
Grade 1......API*
Maximum Performance Signature Series 5W-30 Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W-30 Synthetic Motor Oil (OEFQT) All TEMPS......5W-30, 5W-20 [1]
Manual Transmission,T350 (5-SPD)......AP4
All TEMPS......
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Automatic Transmission,40TE......AP4
Automatic Transmission,41TE......AP4
Fluids
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [2]
Clutch Fluid......HB
Power Steering Fluid......AP4
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [3]
[1] SAE 5W-20, SAE 5W-30 or 10W-30. Check oil fill cap
for proper engine oil viscosity usage.
[2] Hydraulic Brake Fluid, DOT 3
P/N 04318080AB or 04318081AB meeting MS-4574
[3] ATF+4® Automatic Transmission Fluid
Filters
Oil Filter Absolute Efficiency Oil Filter (EA15K51) [1]
Oil Filter WIX 51348 Oil Filter
Transmission Filter WIX 58934 Trans Filter
[1] Replaces the Ea15k33, which will still work for this vehicle
NGK Plugs & Wiresets
GPSERIES PLUG LZTR4AGP
IXIRIDIUM PLUG LZTR4AIX-11
PREMIUMPLATINUM PLUG PLZTR4A-13
VPOWER PLUG LZTR4A-11
WIRESET WIRESET RC-CRX047
Wipers
Blade Class Driver Passenger Rear
ExactFit T201 T211 T161
NeoForm T16200 T16210 T16160
Winter T37205 T37210 T37160
Chassis Lubrication
0-2 Fittings, 0 Plugs..........LB
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLC3P)
Synthetic Water Resistant Grease (GWR3P)
DOMINATOR Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Capacities
Engine, with filter..........5.1 quarts [1]
Cooling System, Initial Fill..........6.4 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 40TE Initial Fill..........4 quarts
Automatic Transmission, 41TE Initial Fill..........4 quarts
Automatic Transmission, Total Fill
4 speed 40TE..........8.6 quarts
4 speed 41TE..........8.6 quarts
Manual Transmission, T350 (5-SPD)..........5.1 pints
[1] After refill check oil level.
Torques
Oil Drain Plug.....20 ft/lbs
Manual Transmission G288
Fill Plug 29-35 ft/lbs
Drain Plug 29-35 ft/lbs
Manual Transmission T350
Drain Plug 10 ft/lbs
Other Top Quality Products
Mothers® Car Care Appearance Products
By-Pass Oil Filters
Diesel Fuel Additive Concentrate
Cold Flow Improver
Cetane Boost Diesel Fuel Additive
PI Performance Improver Gasoline Additive
Old 03 Aug 2015, 09:21 pm
Also I would recommend purchaseing a trans pan with a drain plug, bought a DORMAN trans pan from rock auto, A good investment and makes draining trans fluid alot easier and not as messey.Also if you change the filter be carefull a gush of fluid will stream out if you don't know by now. hope this may help some.
Limp Mode? Bentron General PT Cruiser Discussions 23 21 Jun 2016 10:54 am
Transmission going into Limp Mode KariJ Tech & Performance Forum 1 22 Jul 2014 04:02 pm
Air bag deployment and limp mode Hvymtl Tech & Performance Forum 1 25 Aug 2011 03:36 pm
help..limp mode ivynthemnts758 Tech & Performance Forum 2 09 Sep 2010 08:44 am
01 cruiser in limp mode mui5m General PT Cruiser Discussions 1 04 Dec 2009 02:19 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
