This is a very quick procedure that just about anyone can do at home if you are the least bit handy. So I want to post a How-To with lots of photos.
To start, I bought my replacement multifunction switch at Advance Autoparts. By purchasing it online and using a 30% discount code, I got it for about $42 with tax. And since my local Advance store stocks this part, I was able to just down and pick it up without waiting for shipping. This multifunction switch is Carquest Part Number S14401 for my 2005 PT Cruiser GT. This should fit all 1st Gen PT Cruisers with factory fog lights from 2001 thru 2005. There are other good brands to pick from as well such as Dorman, Standard Ignition and Airtex/Wells.
Failure of the multifunction switch is very common in 1st Gen PT's. The common symptom is that the fog lights will be on even when the lights are off. Often a PT owner will come out to find that his or her PT will not start because the battery is down due the fog lights being on. I noticed my fog lights on when I came out of a restaurant. Normally, the fog lights cannot be on if the headlights are off.
To do this job, I used the following five tools:
* T10 Torx driver
* T15 Torx driver
* Phillips head screwdriver
* 10mm end wrench
* Trim try tool
First, remove the positive battery cable using the 10mm end wrench.
Next, take the Phillips screwdriver and remove the screw from the right and left bottom of the steering column as shown.
There are plastic clips holding the back of the steering column cover together. Reach behind the top piece with a finger and pull out while pressing in and down with another finger or thumb. This will release the clip. Do the same on both sides.
Here is what the clips looks like. They can be easily broken so be gentle.
Now remove the top piece of the steering column cover by raising up on the front and pulling it out. It helps to have the steering column in the down position.
Next, pull the red tab on the back of the plug on the right back side of the switch. Then press down on the plug release and pull the plug loose. You may use the trim pry tool for this. I didn't have to on this PT.
It was helpful to pull the little black plug loose in order to get my big fingers around the switch plug. The little black plug just pulls off.
Now remove the two retaining screws on the top of the switch with a T15 Torx driver.
Cock the switch up from the left side until the windshield wiper plug is exposed on the right. This makes it easy to get to that plug. Just pull the red tab, press down on the plug release and pull. You can also just take out the two T10 Torx screws on the right front of the wiper switch, slide it off the multifunction switch and leave it plugged in. But I wanted to take the wiper switch off so I could clean it. So I left it on the multifunction switch for now.
And here's the new switch on top of the box. It's time to change out a couple of parts.
Use a T10 Torx driver to remove the two screws on the right front of the multifunction switch.
Now the wiper switch will just slide off to the right. Note that the multifunction switch only holds the wiper switch in place. There are no electrical nor mechanical connections between them other than these two Torx screws.
Next, remove the blinker element from the back of the old multifunction switch. I chose to wait to install this on the new multifunction switch after the new switch is on the column. That gives me more room to plug the wiper switch back in.
And here's the new multifunction switch ready to go back in my PT.
Plug both plugs back in and secure the new switch to the column with the two T15 Torx retaining screws. Then reinstall the blinker element.
MORE IN NEXT POST BELOW
