Timing Belt Tensioner Help
Old 10 Aug 2015, 08:35 pm
Default Timing Belt Tensioner Help
Hey guys!
I'm a long time home-garage mechanic, 12 years experience working on various makes and models. A friend of mine had his water pump go out in his 2001 Cruiser and I mistakenly told him I would tackle the job. Good lord that giant bracket was a pain in the ass. I'm a bit stumped with the tensioner that came with my timing belt kit. I've read all about the tensioner upgrade from this style...
To this style...
However, it seems as if he had the new style tensioner but not the new bracket. Take a look at what came off of the car and what came with my kit...
Old Tensioner vs. New Tensioner
Absence of Bracket (I can take the timing cover off if needed, but it's not there)
Do I need to get that bracket? It looks like I do. The contact points between the bracket and the tensioner body (that resists pressure from the spring, putting tension on the belt), are lower on the new tensioner. This leads me to believe that I need the bracket. But then again maybe the back portion of the tensioner (that would contact the tab on the factory "bracket") that is built into the block is what resists spring pressure.
Thanks in advance for all the help!
04 PT Timing belt tensioner havoc999 Tech & Performance Forum 2 08 Mar 2015 08:54 pm
Timing belt tensioner help faysCruzn Feedback and Support 8 16 Oct 2013 08:36 am
Timing belt tensioner Jeepertim Tech & Performance Forum 9 25 Nov 2011 12:39 pm
Timing Belt Tensioner Areus Tech & Performance Forum 0 17 Jun 2011 05:44 pm
Timing Belt Tensioner 06ptbruiser Tech & Performance Forum 11 31 Dec 2010 10:39 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
