2004 PT Cruiser Gt 5-speed 90k miles
I started my car up one morning to have it start shaking at idle. Its worst around 1500 rpm but clears up a little above that. Not throwing any codes. Motor sounds normal, no knocking or pinging just shaking. Replaced all my mounts as they were slightly torn. Checked my timing gears and they line up, pulled the valve cover and cams are still lined up correctly. Timing belt was done at approx. 60k miles and looks fine, no visible wear or missing teeth. Replaced my plugs, dirty from octane booster ![]() I drained my oil last night and noticed the glittery effect in it. Too little light to see if it appeared to be coppery but regardless glittery oil is no good. Would worn/failing bearings cause a rough idle and shake throughout the rpm band? From my understanding when your bearings go out or are going out there's usually the telltale knocking associated with it. Is it possible some bearings are about to fail to where they aren't knocking but will shake the motor? Unsure as to what my fuel pressure is since my stupid fuel rail doesn't have a Schrader valve. Checked my injectors, 2 were at 13 ohms, 2 were at 12.8 ohms. Unsure if they were clogged but they appear to be working fine, clicking and everything. Fuel pump fires right up and sounds healthy but sounds aren't going to tell me if the regulator is failing. Afr sits at 15.1 at idle, use to be 14.7. Kind of all over the board with it too. Would clogged o2 sensors cause this? I have no cat and 2-step a lot, turns out I also shoot flames ![]() Another fought I had is that my diablo tuner somehow fried my ecu or pcm or whatever as I had adjusted my tune just prior to starting my car up before it ran terrible. Thought maybe the metal could be from turbo bearings, unsure if this is a possibility. No shaft play at all in turbo though. Any thoughts or ideas as what my problem could be or anymore tests I could do to diagnose my problem? I'm at a loss right now and will probably end up throwing money at the car to replace parts until it works. |
No, bearings won't cause shake. AFR is high. I'd look at something that controls fuel at idle, ... Map sensor hose "split" Small air leak If it has backfired, a hose could be blown off or split Most probably a sensor if no codes are showing up. IMO Metal in the oil is not normal. Sparkles in the oil are if it is run hard and spark knocks. That makes the Pistons "shutter in the cylinders" and can shave off small particles of aluminum from the Pistons. ... Kind of why high performance engines usually have a shorter life ! ![]() |
I guess the shavings are probably from me beating the piss out of it at the track for a weekend. Its my first time changing oil since then.
Swapped out my camshaft position sensor, in the process of doing my crankshaft position sensor and o2 sensors. What other ones do you think could cause issues? I'm also looking over all my vacuum lines since I have the top half of the motor torn off. |
Thread Tools | |
Display Modes | |
AC fan bearings? | sevans1975 | Tech & Performance Forum | 2 | 24 Sep 2014 09:29 am |
Wheel Bearings | echo | Wheels, Tires, Suspension | 2 | 30 Dec 2013 09:20 pm |
Bearings going out? | StrykrForce | Tech & Performance Forum | 4 | 09 Mar 2012 07:44 pm |
my bearings | ape_stein | Tech & Performance Forum | 5 | 31 Aug 2010 07:04 am |
Help...Hub Bearings??? | delrosen | Tech & Performance Forum | 1 | 05 Sep 2008 09:54 pm |
