Very Low Compression '02 2.4L engine
Like Tree17Likes
Old 22 Aug 2015, 09:15 pm
Default Very Low Compression '02 2.4L engine
I just replaced the timing belt, tensioner pulley assembly and idler pulley. As I was putting it back together, I did a compression check, and have 30-40 psi compression in cylinders 1, 2 and. 4. Cylinder 3 I have about 100 psi.
Haynes manual says all should be reading 170-225psi.
Timing is on exactly. I tore off the valve cover and visually confirmed what timing marks were already telling me. None of the valves appear to be bent or damaged.
I checked the coolant, and there was no froth or foam while I was turning the engine over.
Any recommendations or thoughts on how to troubleshoot from here?
Thanks for the help!
Old 22 Aug 2015, 09:23 pm
Default Re: Very Low Compression '02 2.4L engine
Did your belt break or did the teeth strip off?
You cannot VISUALLY check for bent valves... unless you break one off and embed it side ways in a piston (I did, not on a PT Cruiser)
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
LionPT's Avatar
Dry or Wet test..??
Old 22 Aug 2015, 09:26 pm
Neither. The tenionser pulley failed (all ball bearings came out). The timing was about 1/4 turn off at the camshaft sprockets.
I was told this is a no interference engine, so no damage should have been done due to that.
Old 22 Aug 2015, 09:27 pm
Originally Posted by LionPT View Post
Dry or Wet test..??
Ummm...not sure what you mean... I am fairly green.
Old 22 Aug 2015, 09:31 pm
LionPT's Avatar
Old 22 Aug 2015, 09:38 pm
Thanks! It was a dry test.
Old 22 Aug 2015, 10:07 pm
Are both arrows pointing up. On the pulleys? Did you take pics of the timing marks before closing up? Also did you have the cam sprocket bolts loose during this? There two line up holes in the cam shafts. If the are at top dead center these holes will be straight up and parallel to each other. You can't bend valves multi cylinders. can out of time with the other cam will show very low compression.
Old 22 Aug 2015, 10:21 pm
I already had closed up for the day before posting...so no picks yet. However, yes, the sprockets were both saying "up" and the timing marks and the sprockets were perfectly aligned when crank shaft/case marks indicated TDC. I will confirm the next time I am working on it.
In terms of the camshaft sprocket both, no, they were torqued down to the 85ft lbs spec in the Haynes manual.
Old 22 Aug 2015, 10:29 pm
When you get the chance to look check that the cam didn't rotate in the sprocket and Scheared the line up pin. The holes in the cams are the best way to check for this. I'm off to bed now. Hope you find your glitch. I truly believe it is a timing issue.
Low compression? devindinapoli General PT Cruiser Discussions 28 29 Jun 2018 04:34 pm
Compression Papa2448 General PT Cruiser Discussions 12 10 Jan 2016 12:15 am
compression psi moonshinehd Tech & Performance Forum 7 27 Apr 2012 10:03 pm
The no compression engine PTProblems Tech & Performance Forum 2 01 Apr 2011 09:15 pm
engine low on compression LoWandSloW Tech & Performance Forum 7 02 Jul 2007 09:58 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
