p0712
Old 25 Aug 2015, 05:41 pm
Exclamation p0712
P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input. Does it really matter? Shifts ok. Not sure how this will affect things.
Thanks
2002 2.4 auto 130k and still going.
Old 07 Sep 2015, 10:33 am
Default Re: p0712 bump
bump....................
Old 07 Sep 2015, 11:05 am
Default Re: p0712
can't answer your question, but on our caravan that sensor cost $30 from the dealer.
Old 17 Sep 2015, 04:43 pm
Exclamation Re: p0712
Not running at the moment. Had it towed home. This is the code I am getting right now. P0172!!!! It turns over but no start. I am using the turn the key method to get this code. A while back I did use my friends scanner/ code reader and I recall something about fuel moduel I THINK the 172 was there at that time. As I was driving it it just started running very bad. Limped it to a safe spot and now I am clueless. Anybody know what the fuel pressure should be with key on engine off??
Thanks
Chris
Old 17 Sep 2015, 08:33 pm
Default Re: p0712
Fault code P0172-Fuel System 1/1 Rich
Most of the posts I have been reading with P0172 had engine mechanical problems.
Old 18 Sep 2015, 09:11 am
Default Re: p0712
P0712
or
P0172?
if it's 172 i'd ASSume it's related to the cam movement in your other thread. if it's off or opening too early it may be letting unburned fuel into the exhaust.
to answer your fuel pressure question, fuel pressure should be 58 +/- 5psi.
if you do a fuel pressure test, be sure to do the fuel pressure leakdown test as well. see how much pressure it has (engine off)after a minute, 3 minute, 5 minutes, 10 minutes. it should not drop much. if it does the injectors may be sticking open allowing extra fuel in, causing your code. it isn't as rare as you'e think.
Old 18 Sep 2015, 09:59 am
Default Re: p0712
Originally Posted by rob342 View Post
P0712
or
P0172?
If you suspect dirty injectors try some Berryman's B-12 CHEMTOOL fuel system cleaner. More cleaning ingredients Than Seafoam. Half the price. Can't hurt enem if you have something else going on.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
