First time I've driven an AT PT, is this normal? (downshift lag at a near stop)
Old 05 Sep 2015, 11:27 pm
Default First time I've driven an AT PT, is this normal? (downshift lag/bump at a near stop)
New owner of an automatic PT (2001 limited).
In my other thread you'll see that I had an O2 sensor code that I traced to a pin at the PCM or PCM issue.
Car drives great! Accelerate from a stop, no problems. Decelerate to a stop, no problem.
However sometimes when I'm slowing down/braking to a near stop but then give it a little gas (like turning into my driveway and then needing to get up the hill of the driveway) the trans lags in the downshift then does with a clunk. Well not a real clunk but a seat of the pants jolt. Not severe.
Is this a 'Trans learning' issue from having the battery disconnected for a long time figuring out the O2 issue? Or is this a 'get your TCM flashed/updated' problem. Something else?
Where do I even start diagnosing this?
Edit: some background on the car, from the Carfax report this car has been dealer serviced from new until about 2 years ago. Trans fluid looks like it came out of a bottle - clean clean clean, no burnt smell. 59K original miles so I'm thinking this isn't a 'the trans is going out' problem.
TIA
______________________________________________
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods - replaced
2001 PT Cruiser LE AT 103K miles.
Will a transmission flush stop my rough downshift? bjagd02 General PT Cruiser Discussions 18 24 Aug 2014 07:54 am
2001 overheats when driven, but doesn't when it just sits and idles charity Tech & Performance Forum 3 14 Sep 2013 03:55 pm
Are the dashboard fans driven by toothed belt? jdege General PT Cruiser Discussions 8 04 Jun 2011 07:47 am
Wishin I Could Be Driven the PT GW General PT Cruiser Discussions 20 01 Feb 2004 02:03 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
