I try to start it and all the lights for the gear selector light up on the dashboard. I have disconnected the negative cable for a few minutes and it will reset the light to only light up for park but once I try starting it again it puts all the gear selector lights back on and just clicks...new battery that has tested good...Not sure where to go from here. All other lights come on with no problem...just acts like it is locking the ignition.
Any help would be appreciated. I am trying to avoid having it towed to a dealership |
I am sure you will get more informed responses, but...
What do you mean by tested fine? Is the battery fully charged? Did you try boosting it? Double/triple check the connections? I'm guessing you did since you pulled the negative, but worth a shot. These things can act kind of whacky when the battery is low or the cables questionable. I would try briskly (slamming?) the tilt wheel up and down and moving it in and out of park a few times and/or trying to start it in neutral. Probably won't work, but it is free. Good luck Last edited by Fk5; 14 Oct 2015 at 02:22 pm. |
I would suggest trying to start it in neutral if you can.
2006 - 2008 TSb is for no start- Static locks out the ignition and there are several replacement parts that are updated and need replaced
My 06 is parked---same thing.. New ignition switch doesn't help. Jump starter-- it turns......
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
![]() Quote:
i will try this this weekend thank you!
Have you just tried thumping the dash above the instrument cluster and see if that helps? I know it sounds stupid, but there could be a loose connection there indicating that you need to pull the cluster and check it .
![]() Aspire to inspire before you expire. |
I would suggest checking the starter relay if you are getting some clicking sounds. Try to find where the clicking sound is coming from if its not the starter relay.
i will try this this weekend. Thank you!
Thread Tools | |
Display Modes | |
Remote start retrofit for 2007 Touring? | TroyO | Interior Accessories Forum | 1 | 23 Jan 2014 02:20 am |
Help needed: 2007 PT Won't Start: Alarm / RKE Module - SKIM Key Issues | bluebossa | Tech & Performance Forum | 6 | 05 Oct 2013 11:55 am |
2007 diesel cruiser turns over but wont start after front end shunt | guitarman | Tech & Performance Forum | 0 | 07 Jan 2013 06:37 am |
2007 PT Cruiser Overheated now wont start!! | kbryant | Tech & Performance Forum | 15 | 25 May 2012 03:55 pm |
Pt Cruiser 2007 Does not start | Selim | Tech & Performance Forum | 2 | 06 Feb 2010 09:24 pm |
