05 pt cruiser
Old 15 Oct 2015, 02:43 am
Default 05 pt cruiser
Working on son in laws pt. It fell dead in w m parking lot. Code says camshaft position sensor A Bank 1 circuit malfunction..... Replaced cam and crank sensor... Car will not start. And code still comes up....... Any help ????
Old 15 Oct 2015, 06:42 am
Default Re: 05 pt cruiser
Does it turn over and not start or just dead when you turn the key? How many miles on it?
Old 15 Oct 2015, 06:47 am
LionPT's Avatar
Check the wireing harness above the front passenger side axel...sometimes it will rub against axel causing fryed or broken wires.
chuzz likes this.
Old 15 Oct 2015, 08:05 am
I would suggest removing the camshaft sensor and see if the camshaft is turning when you crank the engine. If the camshaft does not turn you need to check the timing belt.
Old 15 Oct 2015, 08:06 am
[QUOTE=LionPT;587782]Check the wireing harness above the front passenger side axel...sometimes it will rub against axel causing fryed or broken wires.[/QUOTE
Wasn't that cured before 05? I thought that was just a problem with the 01 and 02 models. But, I'm not a mechanic and am wrong a lot more often than I am right.
Hey, hey I wanna be a rock star.
Old 15 Oct 2015, 02:37 pm
It turns over fine. Bout. 129.000 miles.
Old 15 Oct 2015, 03:46 pm
Update..... Cam does not turn ... I'm thinking timing belt... And how hard is it to change...
Old 15 Oct 2015, 03:51 pm
Here's some reading for you......
Timing belt replacement on wifes 2006 NA
ever replace timing belt in a pt cruiser
Replacing the timing belt 2.4L (without a lift!) -Detail instructions
Timing Belt Change Hints and Tricks (Picture Warning!)
Old 15 Oct 2015, 08:08 pm
Has the timing belt ever been replaced on this engine?
Old 17 Oct 2015, 11:12 pm
I know nothing bout this car ..... Get n price on timing belt.. Not up to Jack n with... Thanks to all for the help on his pt......
