Fuel pump relay number?
Old 19 Oct 2015, 06:40 pm
Default Fuel pump relay number?
Does anyone know which is the number for the fuel pump relay in the PDC? My Haynes manual tells me I need to remove this before I remove the intake but the picture they give of the PDC looks nothing at all like mine. Help!
Old 19 Oct 2015, 06:53 pm
Default Re: Fuel pump relay number?
What year do you have
Turbo
or NA (natural aspirated)
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 19 Oct 2015, 07:09 pm
If the picture of the PDC (Power Distribution Center) doesn't look anything like what you have, you probably have a 2nd generation (06-10) PT Cruiser which has the IPM (Integrated Power Modual). According to a search for your answer, I found this.....
This vehicle is not equipped with a fuel pump relay. The fuel pump control is done through the TIPM (Electrical box w/ fuses and relays by the battery). The TIPM receives an input signal from the PCM. Once the TIPM receives the signal, it will output a 12 volt supply to the fuel pump module turning the pump on.
The Haynes/Chilton Manuasl aren't bad for some repairs on the first generation (01-05) cruisers but the upgraded manuals which supposedly covers up to 2009 leaves a lot to be desired including the change of electronics to include the TIPM and Can-Bus system.
Old 19 Oct 2015, 10:51 pm
Very helpful, thank you. Mine is a 2008, NA. I just went ahead and skipped that step, I guess that means I'll just get a squirt of fuel at some point as I dig down toward removing the cylinder head.
Old 19 Oct 2015, 11:21 pm
You may want to mark either the Coil or Cam Position sensor harness connector to make sure you install them on the correct item.
Its possible to cross connect them upon assembly.
73 Charger SE
01 Sebring flip
Fuel pump relay partyd General PT Cruiser Discussions 14 24 Jun 2017 11:42 am
fuel pump relay izcom2002 General PT Cruiser Discussions 7 31 Jul 2014 04:39 pm
fuel pump relay jc1200 General PT Cruiser Discussions 1 23 Feb 2013 01:16 pm
Fuel pump relay overheats nastrk99 Welcome New PT Cruiser Members 10 19 May 2012 03:50 pm
Fuel Pump Relay Location 06 PT goboom2 Tech & Performance Forum 0 17 Dec 2011 03:13 pm
