Camshaft Position
Old 25 Oct 2015, 07:28 pm
Default Camshaft Position
I just removed the timing belt in the process of finding and curing an oil leak and power steering leak. I had to rotate the crankshaft during the R&R of the oil pump, so it was not in the same position as when I started. Got it back together to the point of trying to start it to make sure all was OK. Won't start. Sounds like very little compression, but when I turn it over by hand it does have compression. What is the correct position of the camshafts? With the crankshaft pointing at the timing mark the front camshaft has markings that says "front" and "up" with the arrows pointing up. There is an arrow pointing to the middle of the rear cam. The rear cam says "front" and "up", but the arrows are pointing down. There is also an arrow pointing to the middle of the front cam. Am I not seeing the arrows correctly? Is the rear cam 180 off?
Old 25 Oct 2015, 07:40 pm
Default Re: Camshaft Position
Still looking for a better image
Old 25 Oct 2015, 07:43 pm
sounds like it. Arrows up. Notches pointing at each other. The should line up through the centerline of the cam bolts. For pics. Go to the performance section of the forum. Look for the how to sticky. Go to that. Look for the HOW TO REMOVE THE HARMONIC BALANCER TIP AND TRICKS. Clear pics of the timing there. I'm a on my phone so can't do links with it.
Old 25 Oct 2015, 07:45 pm
rckstein's Avatar
The marks at the center of the cam sprockets are what you need to be concerned with.
Old 25 Oct 2015, 07:46 pm
This one is a better image. I see Rckstein beat me to it!
Old 25 Oct 2015, 10:08 pm
Still needs the crank pic.
Old 25 Oct 2015, 10:57 pm
rckstein's Avatar
How about this?
Old 26 Oct 2015, 07:13 am
That will work.
Tags
cam shaft, markings, timing, timing belt
Camshaft position sensor Strilla Tech & Performance Forum 30 02 Dec 2016 01:09 pm
Camshaft Position Sensor Kurtwk5 General PT Cruiser Discussions 16 17 Jun 2013 02:11 am
Camshaft Position Sensor RiccardoXXV General PT Cruiser Discussions 7 26 Apr 2013 07:52 am
camshaft position sensor hokiecruiser Tech & Performance Forum 16 01 Nov 2012 05:14 pm
Camshaft Position Sensor ejschultz Tech & Performance Forum 6 22 Sep 2010 09:58 pm
