Engine missing on 2 cylinders
Old 27 Oct 2015, 05:58 pm
Default Engine missing on 2 cylinders
2003 Turbo GT model. A/C. 89,000 miles. Car is in shop now. Mechanic replaced Plugs, Wires, Coil. Scan code P02305, Secondary of coil not working (1 and 4 ?). Tried two new coils.
Cold engine starts/runs normal but can be made to fail on 2 cylinders by flooring the accelerator hard. Turning the key off and restarting "resets something" and engine will idle "normal". Don't know for how long.
After engine is warmed up it will fail when under load or going up a hill (without flooring accelerator). If the engine is not too hot, it can be reset back to normal again by turning the key off and restarting.
When engine is hot it can fail under slight load, A/C on or off no difference.
Thanks for any help or suggestions.
Old 27 Oct 2015, 06:18 pm
Default Re: Engine missing on 2 cylinders
i believe there are three wires to the coil. one of the three is for 1 and 4, that is where i would begin troubleshooting. it should be a dark blue wire with a tan stripe.
i would check that one wire for continuity from the PCM to the coil while wiggling the wires around. it should be a simple fix once you find it. usually if a wire is broken internally, it is broken right at the connector.
Old 27 Oct 2015, 06:45 pm
Thanks very much. Will check it out.
Old 27 Oct 2015, 08:26 pm
P02305
Possible Causes:
Cylinder No. 2 spark plug or wire is damaged or it has failed
Ignition Coil No. 2 is damaged or it has failed
Ignition coil control circuit is open or shorted to ground
ASD relay output circuit problems
PCM has failed
As Rob342 posted to check for ignition coil control circuit and see if its open.
when you unplug the connector and plug it back in to the coil, every once in a while the pins on the connector will pushed the pin inside the connector/plug making contact for a few days and then started to lose connectivity.
Old 27 Oct 2015, 08:35 pm
Thanks very much Rob. I'm calling my mechanic with this info. Will keep you posted with anything that works.
Old 27 Oct 2015, 08:38 pm
My bad...thanks PTCRUISERSTEVE...and Rob also
Old 30 Oct 2015, 02:10 am
Tried all the suggestions and we're left with the PCM. Hope this works. Looking for a working used one. Will post results but may take a while since haven't found one yet.
Old 30 Oct 2015, 04:32 am
IF your ignition key has the grey head on it, you have factory security which incorporates, the key, SKIM module and PCM that have tp be programmed together to work. Without the programming the car will start three times for a second or two and shut down. The little round red light will come on on the dash and you will be locked out until the pieces are reprogrammed or you reinstall the original PCM.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 30 Oct 2015, 02:06 pm
Wow, had no idea about that. My key head is grey . Door opener is black. Do you know where I might go to get all the pieces programed to work together? Thanks for the tip off.
Old 30 Oct 2015, 02:30 pm
is the engine trouble code P02305 the only code that comes up each time?
P0300 effecting all cylinders senji Tech & Performance Forum 6 28 Jan 2013 07:22 am
It's back...Mis-fires in Cylinders #3 and #4? sscanlan Tech & Performance Forum 1 13 Jun 2012 11:39 pm
does revving up your engine really helps remove deposit buildup in the cylinders? ProDigit General PT Cruiser Discussions 8 17 Feb 2011 10:08 pm
Liftgate cylinders Nickatnite Tech & Performance Forum 8 17 Jan 2010 06:24 pm
air cylinders Jonez3 Classifieds: For Sale/Trade 8 20 Sep 2005 05:54 pm
