horrible rattling while in D and brake applied
Old 03 Nov 2015, 12:17 pm
Question horrible rattling while in D and brake applied
Help!!! I just dumped $1000 into my 2002 TE PT Auto now I'm having a new issue. While in drive and the brake is applied I hear a horrible rattling noise. I feel like the car has been somewhat sluggish before this new noise started. This summer I had overheating issues and replaced radiator, heater core, thermostat, water pump, and timing belt. Could this be the catalytic converter?? Any ideas or tips would be greatly appreciated. I don't have the money to keep dumping into this pt, but its my daily driver
Old 03 Nov 2015, 12:35 pm
Default Re: horrible rattling while in D and brake applied
The first thing you need to do is run the codes on it and post them here. While you wait for replies, get your rubber mallet or hammer, get up under it and tap the cat con. If you hear rattling, odds are it's clogged and needs replacing. If you're too fat or lazy (like me), crank it up and put your hand near the tail pipe and feel the exhaust. Does it have good pressure or not? If not, it could still be the cat con. If it feels good, then you have a problem somewhere else. Too many possibilities without more info.
Hey, hey I wanna be a rock star.
Old 03 Nov 2015, 12:42 pm
you need to have someone step on the brake in drive and listen for it. it's probably a heat shield and it'll probably stop rattling when you touch it with a broomstick or something similar. there is one over the exhaust manifold and several leading towards the back of the car. if it's loud and annoying, it should be stupidly easy to find.
don't bang on anything.
Old 03 Nov 2015, 12:48 pm
And it could be the engine is shifting because you've got a busted motor mount or two. Bang the hell out of the cat con and the heat shields!
Old 03 Nov 2015, 12:53 pm
wingman55's Avatar
What is "cat con" jargon for? (I assume catalytic converter?)
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
Old 03 Nov 2015, 12:56 pm
why would you recommend anyone bang on something that contains a fragile clay honeycomb inside?
-you wonder why your car never runs right? here:
that'll fix it!
Old 03 Nov 2015, 02:30 pm
EGR system malfunction read from the check engine light codes. Ill get back to you with what the dash codes say...
Old 03 Nov 2015, 02:35 pm
Code from check engine light: Egr system malfuntion
Codes from dash: P 1684 & P 0401
Old 03 Nov 2015, 03:14 pm
usually the P0401 code will return randomly( after a day, a week, etc) when the EGR transducer starts to fail. when mine failed it did not have any effect on performance, it just turned the idiot light on. you can clean and inspect the EGR valve, likely you will see it seems fine and moves smoothly. I just replaced just the EGR transducer on mine to save money. usually people buy the whole assembly, but i didnt. this fixed my problem and saved money in the process. it only takes 5 minutes to change this. IIRC it is only held in by a clip, a connector, and a couple vacuum lines.[/QUOTE]
the rattling is probably separate.. a rusty shield somewhere
Old 04 Nov 2015, 07:36 am
Where can you get just the tranducer, Rob? Back in TN, none of the parts stores offered them separately. You had to buy the whole EGR valve and transducer together. Bunch of crooks! I haven't checked this since the move to hell, I mean Florida.
Lights flickering when brakes applied? turbojerk Tech & Performance Forum 18 16 Apr 2015 10:10 pm
signal light doesn't work when breaks applied SinglerStudios Tech & Performance Forum 6 24 Jul 2014 07:01 pm
Horrible gas mileage maxxheadroom Tech & Performance Forum 3 21 May 2007 08:51 am
anyone have this windshield logo applied? comPuTer General PT Cruiser Discussions 3 25 Jun 2004 10:23 am
