Help with oil leak - '05 PT
  • 1 Post By LionPT
Old 07 Nov 2015, 11:00 am
Default Help with oil leak - '05 PT
Hello all,
New member here - have owned my '05 PT since '09.
The engine has a bad oil leak. The oil is pooling up behind the engine on the drivers side. I've attached a pic to show where - this was taken after I soaked up the oil. There is a hose highlighted in the picture that appears to have some sort of patch on it - I'm wondering if that's the problem? Does that hose go to the oil pressure sending unit?
Please let me know if I can provide more details. Any help appreciated - thank you!
Old 07 Nov 2015, 05:14 pm
LionPT's Avatar
Default Re: Help with oil leak - '05 PT
Originally Posted by ptwag View Post
Hello all,
ptwag likes this.
Old 08 Nov 2015, 11:36 am
Originally Posted by LionPT View Post
Thanks for the help. Going to check it out. Looks like a job I could tackle myself if it is the valve cover gasket.
Old 08 Nov 2015, 12:01 pm
The valve cover gasket replace job isn't too bad. You have to remove the upper intake manifold (a minor pain with EGR on my model) and unbolt the PS reservoir to get room to lift off valve cover. My biggest grip with the job was how expensive that gasket (and the 4 spark plug hole gaskets) was.
Cheers!
'01 PT Limited. silver. auto. TransGo shift kit.
'04 SRT-4. blue. MPStage1. original owner.
Oil Leak Ikster Tech & Performance Forum 8 04 Oct 2015 09:43 pm
Oil Leak keebler95 General PT Cruiser Discussions 5 21 Jun 2013 04:03 pm
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
Leak A Lot Busa_Powered General PT Cruiser Discussions 4 13 Oct 2012 08:00 pm
ATF Leak shlalk General PT Cruiser Discussions 12 24 Mar 2004 09:05 am
