Stumbles out of 2nd when stopping
Like Tree3Likes
Old 22 Nov 2015, 04:39 pm
Default Stumbles out of 2nd when stopping
Noticed a new problem with my 2008 2.4L. When I come to a complete stop, there is a couple moments of what feels like a holding and then releasing as it comes out of second gear. Doesn't feel right. Not sure if it's related, but it seems like the engine is idling at higher RPM than normal. When it's in drive it idles at 1200 and when it's in park it goes up to around 2300. Didn't notice this before either, wonder if it's due to the colder weather? Is that normal for idle RPM?
No codes.
Recently took head off for valve work, not sure if anything I did could be related.
Thanks.
Old 22 Nov 2015, 05:07 pm
Default Re: Stumbles out of 2nd when stopping
Lots of information using the search feature about A604/41TE transmissions on this forums.
If you have not changed your fluid and serviced the the filter and have over 80K the Transmission control pressure switch assembly may be in need of replacing.
Best advise before your problem gets worse and will cost more go to a specialized Transmission service shop and have checked out.
Old 22 Nov 2015, 05:28 pm
Okay, so those idle numbers sound normal? Went from park to drive kind of hard, which made me think the idle was too fast.
I was worried about changing the transmission fluid since it has 106,000 miles and I don't think has ever been done before. I know on older transmissions it's better not to change if it's never been changed before. This hasn't been my car forever (I married into it, hence the name).
Old 22 Nov 2015, 05:30 pm
LionPT's Avatar
No, idle is high. But you can't adjust it, it's handled by the computer.
Old 22 Nov 2015, 05:41 pm
The idle is not correct. I was responding to your transmission issue which is more the immediate concern IMHO?
NOT Changing the ATF because of age or millage sounds like more internet found fact and not reality of empirical information. LOL
Change the fluid and filter!
The only automatic transmission that it is NOT recommend to do any service fluid changing is those that claim to be lifetime fluid by the manufacture. *see BMW. Those transmissions can actually be damage by changing the fluid.
Old 22 Nov 2015, 05:45 pm
Bill wouldn't it be better for him to look for a vacuum leak before PCM adjusting? He mentioned a head change or removal, so lots of things got touched,bumped,broken,not reconnected forgotten...etc.!
Old 22 Nov 2015, 05:53 pm
LionPT's Avatar
I didn't tell him to adjust the PCM, I said the idle was too high & that the computer controlled it. I didn't tell him to fix anything, I was waiting to see what other info he would post.
NitroPT likes this.
Old 22 Nov 2015, 06:13 pm
I didn't tell him to adjust the PCM either, I said the idle was too high. I was also waiting to see what other info he would post.
On the rpm issue I would suggest checking your vacuum hoses are not leaking. Some of these vacuum hoses are hidden and you need to check all the vacuum hoses especially the PCV hose to the throttle body.
Also suggest checking the two cables that run across the top of the engine. One is the throttle, the other is the cruise control. Check for free movement of the wheels that control those cables. Check for binding of the cables or any place the cables might be rubbing.
Make sure you plugged the IAC and TPS back in and the connectors are properly seated. They're hard to see and easy to overlook.
Your intake manifold might be leaking if your intake manifold gaskets are not sealing properly. Some members have had the intake manifold gasket not sealing after removing it to do a valve job.
Old 22 Nov 2015, 07:11 pm
Yep, PCV valve. I think I inadvertently bumped it earlier today while lifting the air cleaner for an unrelated issue and the nipple broke right off. Replaced valve and old hardened hose and it runs like a charm. Downshifting is smooth now too.
Thanks for all replies. Learn something new every day with this car.
Probedude likes this.
09 PT Overheating, stumbles while idle, A/C blows Pressure out of a valve next Rtire Bishop_usmc General PT Cruiser Discussions 5 03 Aug 2015 09:04 pm
oil light when stopping? j0e General PT Cruiser Discussions 17 07 Jul 2014 11:31 pm
2002 PT stumbles at speed - thx for any help BlueInGA Tech & Performance Forum 3 25 May 2012 03:00 pm
2005 PPT Cruiser Still Stumbles after lots of work done. qcruiser Tech & Performance Forum 8 12 Jul 2011 08:56 pm
01' PT stumbles, barely runs jarvisxl Tech & Performance Forum 2 23 Jun 2011 06:14 am
