car heats up while driving on freeway, but normal in city
Like Tree3Likes
  • 1 Post By quicksilverdon
  • 1 Post By pasadenahotrod03Dreamer
  • 1 Post By donn
Old 22 Nov 2015, 08:56 pm
Default car heats up while driving on freeway, but normal in city
Its probably on here but I could find it...
yesterday driving to work and the temp when up, reached the 3/4 mark...ran the heater on high and helps but not all the way back to normal.
So I stopped and got a low fan relay and replace it all was find drinving in the city but on the highway temp went up...again ran the heater on high and made all the way home 47 miles.
This morning I replace the high fan relay, thermostat and radiator cap. Drove around the city all day from store to store and absolutely no problem. But as soon as I got on the freeway after a mile the temp climbed up to 3/4 mark...ran the heater and temp stopped climing and once off the freeway the temp dropped but still a bit over normal.
By the way, I had replaced the radiator fan about 2 months ago because of bearing went out.
Nothing in the oil, no smoke out of the exhaust. So what do you all think, Head Gasket?
I will need to figure out a way to pressure test the cooling system, tools needed and were to rent what I need to do it. I seen it work on the low side when I turn on the AC and when the car was sitting in driveway but I need to test the hight side?
Thanks in advance...will be checking on youtube...for more insight!
Black 2004 and Silver 2005 Limited Edition, when all else fails "RTFM"!
Old 22 Nov 2015, 09:25 pm
Default Re: car heats up while driving on freeway, but normal in city
Do you think your radiator could be clogged?
Engine generates the most heat in freeway driving. Radiators starting to clog would show up in your type of driving - at least it did for my other cars.
______________________________________________
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM)
- 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half!
- 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job.
2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family
Old 22 Nov 2015, 09:28 pm
Fan shouldn't come on at high speed, so I don't think it's your fan.
I suspect a clogged radiator - enough coolant makes it thru to get rid of heat at low speeds, but when you are at speed and engine is making more power, there isn't enough flow thru radiator to get rid of heat.
See if you can get radiator flushed - can't hurt.
Old 22 Nov 2015, 09:30 pm
Took me a while to compose my reply, then when I hit enter I saw yours - great minds think alike!
Probedude likes this.
Old 22 Nov 2015, 09:54 pm
If you determine it is a clogged radiator don't have it cleaned out, just replace it with the best new one you can buy. Modern radiators are throwaways.
LionPT likes this.
Old 23 Nov 2015, 12:20 am
Are you loosing coolant or is the coolant coming out of the coolant overflow container?
Are you using HOAT coolant?
Old 23 Nov 2015, 08:01 am
Have you done a flush on the radiator and heater core? IF not, try that and replace the thermostat and put some new 50/50 antifreeze and distilled water in there. I agree that it sounds like the radiator isn't flowing correctly, but if it's clogged, then odds are pretty good that the heater core will be too. Try the flush first if you do the pressure test and don't find any leaks.
Hey, hey I wanna be a rock star.
Old 23 Nov 2015, 02:01 pm
Thanks guys...
I will be doing a flush over the holiday off time...Valvoline™ ZEREX™ G-05™ Antifreeze / Coolant will be what I am going to put in the radiator as well.
I have replaced the following:
Rad cap
Thermostat
Low and High Fan Relay's
And fan was replaced a month or so ago.
I am going to flush it and will replace with new fluid and while I am at it I will take out he radiator and look for any trash that between the AC condenser and the Radiator.
I think its in the radiator and I found new on line for $56 so worst case I will order one if I have to.
Thanks again for the assist, Happy Thanksgiving!
Old 23 Nov 2015, 05:07 pm
Be sure to come back and let us know if you get it "cured".
Old 23 Nov 2015, 10:22 pm
Will do!
Hot then normal Tucker05 Tech & Performance Forum 5 29 Sep 2015 08:04 pm
Tie Rod Normal? falconut Wheels, Tires, Suspension 2 31 May 2014 07:43 pm
2005 Convertible turbo slight shudder/bucking at freeway speeds. Deen General Turbo Discussions 0 09 Jun 2012 06:26 pm
has anyone had there revlimiter come on while driving normal jayln Tech & Performance Forum 2 31 Oct 2011 08:38 pm
Stall on freeway - code P00344? tezz Turbo Performance 15 13 Aug 2008 05:21 pm
