Starting and Idling Problem, P050ab code.
Old 27 Nov 2015, 05:32 pm
Default Starting and Idling Problem, P050ab code.
Hi,
I recently acquired a 2006 Cruiser with 67000 miles on it. It's the regular 2.4 manual. It runs fine at speed but has trouble starting unless I give it gas and will stumble and almost die when at idle. It just smogged and they replaced the MAF sensor. I thought it might be a throttle body problem so I cleaned the throttle body. Another symptom is that it has a higher pitched wheezing sound when revved up, not sure if it could be a vacuum leak. There are no oil leaks or coolant leaks that I can find.
Autozone gives this description for the codes:
Cold Start Idle Air Control (IAC) System Performance
Possible Causes:
Air inlet duct is collapsed, loose or air filter element is clogged
A parasitic load on the engine
Base engine problem (i.e., compression or misfire condition)
MAF sensor is dirty, out-of-calibration or it is "skewed"
Throttle plate, throttle shaft or linkage is damaged or sticking
ECM has failed
Anyone have any ideas? I'm concerned it might be a cracked head or a bad valve, so I'd like to rule out anything else before I pull everything and do a compression check.
Old 27 Nov 2015, 06:28 pm
Default Re: Starting and Idling Problem, P050ab code.
With you saying it has a high pitched sound, it seems to me like your most likely culprit is a vacuum leak. Get some carb cleaner and start the engine and let it idle (if it will) and start spraying around the throttle body and intake. If there's a leak, when the carb cleaner hits it, the idle should change noticeably.
Hey, hey I wanna be a rock star.
No code idle issue when first starting. mdfrodolives Tech & Performance Forum 4 24 Mar 2015 03:20 pm
Another starting problem rockingordo General PT Cruiser Discussions 10 02 Dec 2013 03:32 am
Problem with Idling? 03TibbyGuy Tech & Performance Forum 6 19 Oct 2010 11:51 am
01 PT Problem with starting car Vengence General PT Cruiser Discussions 1 04 Apr 2009 01:29 pm
starting up problem packrat007 Tech & Performance Forum 11 15 Aug 2008 04:38 am
